Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-10-2012, 07:57 PM   #1
concrete block step crack - load bearing wall
I have a cinder block/stucco house in Florida. A step crack has developed on an exterior wall that is a load bearing wall. The crack begins at a window and "steps down" to the floor. There is very little/no seperation in the crack -
the builder suggest caulking and repainting.
What is recommeneded as the preferred repair method?
CBrett
cbrett1979 is offline   Reply With Quote
Old 03-10-2012, 08:28 PM   #2
CBrett
This should help: http://www.ehow.com/how_7855696_fix-concrete-block.html
epson is offline   Reply With Quote
Old 03-10-2012, 08:30 PM   #3
CBrett
What did the builder say the reason for this?
framer52 is offline   Reply With Quote
Old 03-10-2012, 11:07 PM   #4
concretemasonry's Avatar
Is there a crack in the slab at the bottom of the short crack up to the window corner?
Dick
concretemasonry is offline   Reply With Quote
Bathroom Remodel - Resurfacing Plaster over Concrete Block itcanadian Remodeling 2 05-30-2011 11:10 AM
my concrete retaining wall has a major crack where the wall has now shifted DanDaMan Building & Construction 1 04-02-2011 12:34 PM
Replacing load bearing wall KarlJay Building & Construction 3 01-05-2011 05:03 PM
Bearing on concrete block wall Toolmaster Building & Construction 2 08-28-2009 08:11 AM
Load bearing wall in basement Ezekiel Building & Construction 3 11-12-2008 10:23 PM
