Concrete Block - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-03-2012, 03:48 PM   #1
concrete block
about how much does it cost per block to build a crawl space foundation?
dean1121 is offline   Reply With Quote
Old 09-03-2012, 03:49 PM   #2
about how much does it cost per block to lay a crawl space foundation?
Old 09-03-2012, 03:58 PM   #3
concretemasonry's Avatar
Rewards Points: 2,570
Call a couple of reputable mason contractors in your local area for a good range of good work. They know the labor rates and the local requirements. They will not be as cheap as a friend of a friend of a friend.
If they don't bid it, it may be too small or just take you as a shopper. Good contractors rely on repeat business, but they might have some good employees that will do a small job while moon-lighting.
Dick
concretemasonry is online now   Reply With Quote
concrete block house shower medalta Building & Construction 3 11-02-2011 06:16 AM
Cold air coming through joist holes in concrete block foundation. Ptron Building & Construction 2 01-30-2011 05:29 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 04:55 PM
Basement Concrete Block Mortar Seepage Advice Nightcrawler Building & Construction 6 09-22-2009 09:57 PM
Can foam sealer be used to seal the spaces in concrete block? marksto Building & Construction 6 04-21-2008 08:48 AM
