Concrete Binding Agent For Basement Floor Patch? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-14-2013, 03:16 AM   #1
Rewards Points: 127
concrete binding agent for basement floor patch?
Long story short..I have a square hole where the previous owners installed a shower.. got ground water a couple years ago and so I tore the shower out.. they did not fill in around the drain just left it down to the dirt... Before I fill this hole, a guy recommend a bonding agent like quickrete bonding liquid... Said paint it on the sides of the hole before I fill it.. do I need to, or can I just fill it? Under the toilet was the same way so I cut a larger hole around the drain for it.. just wondering before i pour it in
sh40674 is offline   Reply With Quote
Old 03-14-2013, 05:48 AM   #2
Rewards Points: 4,578
he's probably talking about a latex sold in apron/vest stores,,, what can it hurt other'n it only comes in gals, 5's, & 55's ? personally i'd just wet the sides & fill in w/patch conc,,, too bad you're not closer - just about to throw out last fall's leftover gal
Old 03-14-2013, 06:09 AM   #3
Rewards Points: 127
Here's what it is
http://www.quikrete.com/productlines...ngadhesive.asp
What do you mean wet the sides?
Old 03-14-2013, 07:31 AM   #4
had a gc who wanted us to use it - same stuff - its probably better'n the old way of making up a slurry of cement/wtr but apologies for not realizing how much a newbie you might be.
so existing doesn't suck out the moisture new conc needs for proper curing, many often spray/wet the existing,,, there's a condition call'd ' surface saturated dry ' which means the existing conc won't absorb any more wtr yet there's no standing/pooling wtr - that's what i meant
Old 03-14-2013, 07:41 AM   #5
Rewards Points: 127
So just spray the sides with water or use the bonding adhesive?
Old 03-14-2013, 11:41 AM   #6
Rewards Points: 3,518
Or mix some cement with water,and paint it on the exposed sides just before you pour the patch.
Canarywood1 is online now   Reply With Quote
Old 03-14-2013, 01:34 PM   #7
just as Canary sez,,, not a real THICK paste, tho,,, we still wet existing & use paste/grout consistency IF an inspector requires,,, don't let it dry out before placing the conc, tho
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
Need of some help with concrete driveway & patio? imola ghost Concrete, Stone & Masonry 25 04-05-2012 09:03 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
