Concrete Animals - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-21-2012, 11:52 AM   #1
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
concrete animals
2 years ago my wife bought some molds to make small concrete animals. She poured them and they came out great. She got ill and had to quit. She has since recovered and has been trying it again. They just crumble. She is using the same mix as before. She started with cement left over from 2 years ago, when that didn't work, we bought new. Any idea?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 05-21-2012, 12:11 PM   #2
Rewards Points: 152
What kind of concrete were you using before?
TRUEPRO is offline   Reply With Quote
Old 05-21-2012, 07:34 PM   #3
Too Short? Cut it Again!
Was the mix you bought really new or just new to you?
Old 05-21-2012, 10:38 PM   #4
Rewards Points: 42
The portland cement had just come in and was still wrapped in plastic on a pallet.
Old 05-21-2012, 10:47 PM   #5
concretemasonry's Avatar
Rewards Points: 2,578
rusty -
How long did the concrete cure before trying to strip from the mold and what was the temperature?
Could there have been any salt or sugar in the sand?
What kind of molds (rubber plastic, wood, etc,)?
Did you spray anything into or onto the mold surfaces before filling?
High early cement (TYPE III) or reasonable heat and moisture during curing will give you higher early strengths and make stripping easier if you get anxious to make more quickly.
Dick
concretemasonry is offline   Reply With Quote
Old 05-21-2012, 11:33 PM   #6
Rewards Points: 42
The sand is play sand, sold for use in sandboxes.
Latex molds.
Release agent is 2 parts castor, 15 parts rubbing alcohol. (As per mold maker)
Mortar is 3 parts perlite, 2 sand, 1 cement. (again as per mold maker)
This all worked fine 2 years ago. It has been a little cooler so she increased set up time from 24 to 48 hours. Temp is 80's high to 60's lows.
Old 05-22-2012, 10:16 AM   #7
Perlite is like vermiculite (but not as bad) can break down with over-mixing, causing a larger surface area and a greater need for cement. There could also be salt contamination since often a bagging plant will also produce sand for ice removal/traction.
Dick
Old 05-22-2012, 05:00 PM   #8
Rewards Points: 42
Thanks, I'll tell her.
Old 05-22-2012, 05:35 PM   #9
Dick
Used to get sand that was supposed to have been but was not from seaside environments in the landscape industry. If we did not catch it, the salt threatened newly planted plants.
Make sure you are buying washed sand.
Old 05-22-2012, 06:27 PM   #10
I make concrete statues. I have used dozens of mixes and products. what I have found works well is to use quikcrete non-shrink grout. Big yellow bag, use a 3/8" drill and paddle mixer. I also use the occasional sand topping mix with an acrylic admix, quikcrete or acryl-60 from Thorobond. Sometimes I use acryl-60 in the grout too.
It is fun to make your own mix, but buying bag mix is much, much easier and more consistent.
I have found the grout to be about the best, it is designed for precast concrete, captures detail well and holds up over time.
Storyteller is offline   Reply With Quote
The Following 2 Users Say Thank You to Storyteller For This Useful Post:
Ravenworks (05-22-2012), rusty baker (05-22-2012)
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 10:08 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
