-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   concrete amounts for in ground basketball hoop (http://www.diychatroom.com/f105/concrete-amounts-ground-basketball-hoop-166329/)
Nolee 12-12-2012 07:39 PM
Getting ready to set the pole in the ground for a basketball hoop system. Wondering if a 12in ground sleeve tube down 3 ft will equal the recommended 18in diameter circle down 2 ft. It calls for 6 90lb bags of concrete. The pole sits in the concrete 14.5" deep. I live in North TX .. Wichita Falls area ...Any suggestions or comments for this project would be appreciated. Thanks.
concretemasonry 12-12-2012 08:05 PM
A little larger diameter, a foot or so deeper and few cheap bags of concrete are cheap compared to replacing it.
People are getting stronger, bigger and more aggressive, so what works today may not be enough for the near future. If it just for some casual shooting, what you suggest may be adequate.
Dick
Nolee 12-12-2012 09:14 PM
Larger diameter then 18" ? Should i even bother with the sleeve ? Thanks
stadry 12-13-2012 03:15 PM
installed ours as a flagpole - sleeve was encased in conc then b-bal upright inserted into sleeve & that cavity fill'd w/sand,,, work'd well for yrs even in upstate ny where we'd get 3 - 4' of frost,,, come spring, easily straightened :thumbup:
Guywithskills 01-04-2013 11:15 PM
Be sure it is level, winch straps onto pole and nailed to stake in ground. After pour, ck to insure still straight.
FlagRunner 07-29-2013 10:35 AM
If you are going to do a flagpole foundation install, make sure you consider the wind loads on the post. Typical rule of thumb for flagpole in-ground install is 10% the total height of the flagpole. Also consider the frost line. @itsreallyconc makes a good point. Also, if you keep the sand dry between the pole and steel sleeve, the sand should harden to 95% that of concrete and straightening won't be an issue.
