Concrete Against Brick - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-16-2014, 09:06 PM   #16
Rob
Robpo's Avatar
Rewards Points: 826
Originally Posted by jomama45 View Post
This is a couple year old post, but just so it's not too confusing, the "expansion" joint actually has a more important job in this scenario, as a bond breaker. If the concrete is poured directly against the rough brick face, it can "lock" into it and create damage when the slab-on-grade moves...........
WE NEW THAT
Robpo is offline   Reply With Quote
Old 06-16-2014, 10:44 PM   #17
Rewards Points: 1,220
Not only are you almost always wrong, but you can't spell for chit either, Robpo.
Anytime hard materials meet hard materials in a cold joint it needs to be a soft joint with dimensions that exceed maximum expected movement of both members. Asphalt impregnated sugar cane fiber is the most common and cheapest with characteristics that make it almost ideal for this application:
It is more or less waterproof, it is cheap, it lasts a long time, and is able to rebound from normal expansion and contraction to maintain the seal. For critical applications, you can apply a backer rod and joint sealant over the expansion joint.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is online now   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
jomama45 (06-17-2014)
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
concrete drive and walk 7echo Landscaping & Lawn Care 12 04-22-2011 06:03 PM
Concrete over brick??? (updating a fireplace) cwelte Remodeling 11 03-28-2010 01:34 AM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 04:04 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
