#1 |
concrete against brick
Can a concrete patio be poured above existing foundation against the wall brick?
#2 |
Not enough info, no pictures of what you have now, hard to say.
| The Following User Says Thank You to joecaption For This Useful Post: | baldydan (05-09-2012) |
#3 |
concrete against brick |
#4 |
baldydan -
Where are you located and what is the climate? In a cold/cool climate the patio can move and there should be some sort of a "soft joint" between the concrete and more permanent house. If there is a possibility of water (rising or blown) getting to the brick, you could create an interior water/moisture/mold problem because of the bad elevation comparison. Your patio may be too high for site and drainage. Dick |
#5 |
You will be fine pouring concrete up to the brick. Some contractors will put expansion joint material against the brick because the concrete will crack away from the brick. The expansion joint material "EJM" will eventually deteriorate and leave you a bigger gap then what the concrete settling away from the brick will. Pour the crete right up against the brick. If you concerned about moisture, wait until you see the separation of the crete from the brick (which might take some time) and fill the void with elastomeric caulk. This will keep the water out and allow for any more expansion.
Good luck. |
#6 | |
Concrete & Masonry
concrete against brickQuote:
Should you have concern pouring concrete above the foundation line? Yes, the wood skirt, mud sill and floor joists are far more likely to rot out much faster. That being said, there's not always a feasible option. |
#7 | |
#8 | |
Concrete & Masonry
You'll be hard pressed to find an advantage to not installing expansion material, other than laziness & a few cents per foot, or a true professional in the field that wouldn't suggest it's use. |
| The Following User Says Thank You to jomama45 For This Useful Post: | concretemasonry (05-10-2012) |
#9 |
A method we often use when a path or patio is less than 6 inches below the Damp proof course is to lay a line of thin kerb stones about 6 inches away from the wall and take the concrete up to them.
The other side next to the wall has gravel at a lower level than the DPC. |
#10 |
I have never seen "EJM" (a lumped together group of various materials with different properties) in a professional specification for a project, but the specific acceptable acceptable materials are specified and the installation methods are called out for good reason.
Caulk or unknown elastomerics are just a goop and short term solutions that may work for a season or two until the effects or ineffectiveness of the plan and INTSALLATION is discovered TOO LATE. The wait for the crack, caulk and then the wait for the failure is a typical and costly approach in the end despite the cheap concept in the beginning. You know there will be a crack, so plan on it and do a proper installation at the beginning. The same thing applies to the joint between the old patio and the new slab that was ignored. Dick Last edited by concretemasonry; 05-10-2012 at 03:37 PM. |
| Display Modes | |
| Bamboo on modified concrete pad | jhanson | Flooring | 0 | 10-08-2011 12:58 PM |
| concrete drive and walk | 7echo | Landscaping & Lawn Care | 12 | 04-22-2011 06:03 PM |
| Concrete over brick??? (updating a fireplace) | cwelte | Remodeling | 11 | 03-28-2010 01:34 AM |
| Sealing historic brick | tenzo | General Discussion | 2 | 11-22-2008 04:04 PM |
| new concrete floor next to old concrete floor | mattroos | Building & Construction | 10 | 08-28-2007 02:32 PM |
