Cold Weather Concrete Job Questions - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-19-2013, 12:37 AM   #1
Rewards Points: 89
I am converting a screened patio into a conditioned living space. The patio has a foundation that is concrete block. I am currently building concrete forms on top off/around the concrete block so I can pour a concrete cap on top. This top will serve as the top of the foundation wall for the new living space. I will be adding a sill plate on top of the new foundation cap.
The temperatures are currently ranging from the 20's to the 40's. I have placed a concrete insulation blanket on the wall/form, and extending out onto the ground that surrounds the concrete block. I was going to leave this in place for the next four days, then pour the top on Saturday morning.
I will be using Quikrete 5000 concrete mix (high early strength and rapid strength gains--walk time of 10-12 hours) along with hot water and a electric concrete mixer. The total amount of concrete should be about 4 cubic feet.
24 hours before the pour, I was going to enclose the patio with plastic and install a high btu kerosene heater with a vent fan (to avoid carbonation). I was then going to run it for one week after the pour and leave the insulation blanket in place as described.
Can anyone comment on my plans?
Thanks.
toddmanqa is offline   Reply With Quote
Old 02-19-2013, 06:26 AM   #2
Rewards Points: 4,796
other than adding pins & scrub coat of paste to anchor the new pour to the old ? no but i wouldn't use hot water for 5b of conc. good luck !
Old 02-19-2013, 04:42 PM   #3
Rewards Points: 3,824
Sounds like a plan,go for it.
Canarywood1 is offline   Reply With Quote
Polished and Unpolished Concrete Floor Questions pretzels Flooring 5 03-05-2012 03:27 PM
Door Problems in Cold Weather coldnyc347 Building & Construction 5 02-04-2011 04:24 PM
Floating Concrete Outside Pad Questions diycc2 Building & Construction 18 10-18-2010 11:12 PM
CFLs and Cold Weather Jazan Electrical 3 02-19-2010 11:09 AM
Concrete questions Focus2005 Building & Construction 1 05-31-2005 05:05 PM
