Cold Weather Cement Mixer Operation - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-27-2013, 06:46 PM   #1
Cold weather cement mixer operation
I am new to this forum so i dont know if i have missed this subject.
I drove mixer from july 2000 to oct 2005 then left, i have recently returned to the industry in july of 2012, they are right once its in your blood you cant get rid of it.
The question i have is, In extreme cold weather what is the best way to get a drum to turn when it has stopped (before loading)?
When you first attempt to start a drum and the hydro fluid is like syrup we put hot water to the hydro filter which seems to work.
If you throttle up the truck the drum stops, using hot water on the filter starts it going again, If you throttle down it will restart also after a moment or two.
Also if you get it moving in the charge direction, and change directions you are back to square one, a stopped drum.
Is there a "best" way to work around this problem?
Thanks.
Maine mixer man is offline   Reply With Quote
Old 01-27-2013, 06:52 PM   #2
Rewards Points: 13,256
Use oil with a lower viscosity.
Old 01-27-2013, 06:56 PM   #3
DIY staff
Rewards Points: 7,174
Welcome---We actually have a mixer driver as an active member----Mort---
Also a bunch of members who are familiar with fluid drives----some one will help---Mike---
Old 01-28-2013, 10:43 AM   #4
Rewards Points: 216
if hot water does it. use a propane torch to heat it up. the propane will not get the part hot enough to damage it, well, unless you are purposely trying to damage something.
Fix'n it is offline   Reply With Quote
Old 01-28-2013, 11:44 AM   #5
Concrete & Masonry
Rewards Points: 526
Assuming you plug in the block heater every night already, I'd push the company to supply you with one (or more) of these:
http://www.amazon.com/Wolverine-Hydr..._tab_pd_bsnr_2
PS, ensure that the hydraulic tank is metal rather than plastic, as these things can be too hot for plastic sometimes......
jomama45 is online now   Reply With Quote
Old 01-28-2013, 12:47 PM   #6
Rewards Points: 3,410
What do you call extremely cold weather?
Is the equipment parked outside during the night?
Are the hydraulic filters changed regularly?
Do you let the unit warm up for a while before you start to load?
Canarywood1 is offline   Reply With Quote
Old 01-28-2013, 01:29 PM   #7
concretemasonry's Avatar
Rewards Points: 2,578
It sounds like the OP is working with the wrong concrete supplier using obsolete equipment with no weather protection irregardless of the weather that good suppliers cannot afford to run.
Here we have very cold weather and the good suppliers shut down some plants (whith hot mixing water and internal aggregateto funnel production through) and rotate trucks for annual maintenance schedule. The trucks are heated or plugged in and started before a driver gets there and they are ready to go.
Dick
concretemasonry is online now   Reply With Quote
Old 01-29-2013, 12:35 PM   #8
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
What kind of equipment are you using? We run newer McNeilus bodies (2003-2007), and we don't really have a problem with the hydraulic oil getting too viscous. Granted, it probably gets much colder in Maine (even though we're about the same latitude, go figure), but as long as you get that fluid circulating right when you fire the truck up, it would have to be pretty friggin cold to make the drum not turn.
Maybe post a pic of your truck so I can see where the pump is, etc. Maybe it isn't insulated enough. Also, do you know how long it's been since the system has been flushed?
Also, make sure to blow out your water system. Frozen hoses can turn a good day bad really quick.
I hate signatures.
Mort is online now   Reply With Quote
Old 01-29-2013, 05:00 PM   #9
Thanks Mort,
I also figured we are close to the latitude, We flushed the hydro system since i posted this question so hopefully we have cured this problem.
We also run Mcneilus equiptment, this problem doesnt present itself too often i was just looking to see how other drivers have remedied this problem. We are a small family owned/run company. The owners purchased 4 new trucks last year, and over the years have updated the fleet.
Old 01-29-2013, 07:05 PM   #10
" We flushed the hydro system since i posted this question so hopefully we have cured this problem.
this problem doesnt present itself too often i was just looking to see how other drivers have remedied this problem."
The company i worked for had 120 mixers in 5 yards,and as far as i know we never had that problem,and all of our hydraulic pumps were front mounted,but we operated in Chicago and temps were usually no colder than the upper teens and rising before anyone would try to pour.
I would guess that by flushing the system you'll see an improvement though.
Old 01-31-2013, 09:56 AM   #11
Mort's Avatar
Rewards Points: 690
How did that flush work out?
I hate signatures.
Husky Cement Mixer jm0027 General DIY Discussions 4 12-16-2011 04:08 PM
Flooring over Cold Cement bliss208 Flooring 3 08-04-2011 01:41 PM
Cold Weather Interior Painting psustang89 Painting 7 05-19-2008 12:47 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
