CMU For Patio Wall. LW Or HW - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-19-2012, 07:54 PM   #1
Rewards Points: 117
CMU for patio wall. LW or HW
I'm building a small L-shaped sitting wall. 11x11' @ 24" high.
I want to use CMU and then set some manufactured stones over it (stonecraft or coronado for example).
The CMU blocks at my local home depot or lowes are showing 27 and 28 lbs, but I see other blocks online weighing in over 30lbs.
Bottom line: what would be a minimum weight to ensure this wall is sound? Would these 28lb blocks be able to provide enough stability?
It's being put on earth (packed and gravel substrate).
thanks guys, as always.
Dornier is offline   Reply With Quote
Old 03-21-2012, 07:32 PM   #2
Remodeling Contractor
the light weight blocks are for ease of installation and will not make the wall weaker at all. But they cost a bit more, you pay for being a wimp! Proper drainage and a proper footing will make the wall, seat work.
Old 03-21-2012, 10:32 PM   #3
Rewards Points: 117
I'm finding them for around $1.50 ea. as long as the wall is sound I don't mind lifting the heavies.
Thanks a lot for the reply.
Old 03-22-2012, 06:12 AM   #4
MarginallyQualified
Rewards Points: 2,464
How about using the split face with a proper concrete footer too?
Three courses above grade (one below) and you have a good bench height.
Removing a portion of a load bearing wall WFCC Carpentry 3 09-17-2011 06:17 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 06:42 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
