#1 |
CMU Foundation Spalling
I recently became concerned about some joint stepping on my CMU foundation wall just above and below grade, outside and in, at the back west side corner (one side only). I called in three reputable foundation companies and they advised me that I do not have a structural problem and simply tuck point the joints and parge the horizontal CMU spalling. The horizontal spalling is from two patio stones rubbing against the CMU over the years, and no one could identify any reason for the stepping.
After starting my prep work for tuckpoint and parging I’m wondering again about the corner CMU that’s sitting 2/3 below grade The deterioration seems more evident after removing the loose material, and it certainly seems like I could keep lightly chipping away at it. I’m worried that parging it with a parge mixture isn’t going to help me if moisture starts getting in there again. Am I wrong? If water gets in between the block and parge ins't it possible moisture might wick up through the area further adding to the deterioration? Doesn't this happen anyway since the black bituminous parge coating isn't water proof and only damp proof? Picture #1 shows stepping from inside (pic taken about a month ago). Pics 2 & 3 show outside wall as it was when foundation people stopped by (white powder is ant repellant). Pics 4 & 5 show the outside wall after some prep work for repair (taken today). ![]() ![]() ![]() ![]() ![]() Note: the roof over hangs this area quite a bit and the land grade slopes away from the corner. I have witnessed a few heavy rainfalls since finding the problem and not a lot of water hits the corner, and there’s no evidence of any water penetrating the house at this location. The house was built in 1965 and I took procession 2 months ago. The home inspectors also said the stepping wasn’t a problem. Inside pic shows previous patch job. |
#2 |
Recommendation:
Pressure wash area clean as possible. Paint with concrete bonding agent. Parge with type S masonry cement Paint with concrete waterproofing agent. (3 coats) This should keep the problem from re-occurring. It looks like water was sitting there, absorbing into the block, freezing and cause the spall? Just a theory. As far as the stress fracture in the mortar joints... Yes the foundation has settled. They all do. But.... you say no water is getting over there but it looks like it is. 2 sure signs of water damage, cracked joints and spalling. Might want to double check eh? You would think the brick would show some sort of sign as well, right? Usually when the foundation sinks you see it in the brick as well. Maybe not if wall ties were used but you said the house was built in the 60s? Tricky one here... GL Last edited by TRUEPRO; 09-26-2012 at 02:16 AM. |
#3 | |
CMU Foundation SpallingQuote:
It's the classic case of the different properties of clay brickwork and CMUs when used together. Over time, clay brickwork expands slightly as the initially kiln-dry bricks take up moisture from the air. Conversely, CMUs shrink after construction, often giving the familiar stepped cracks. (Although stepped, your cracks seem to run in and out down aternate courses, which suggests expected shrinkage. The time to worry would be if they ran down diagonally at 45 deg.). My guess is that the cracks have been there a long time and don't suggest anything serious, just water penetation. Keep it simple and just do what the foundation people have suggested. |
#4 | |||
Thanks! Last edited by lilbilly; 09-26-2012 at 02:22 PM. Reason: clarification |
#5 | |
Sounds like a good plan. Thanks for the advise. |
| Display Modes | |
| Spalling foundation wall | john6214smith | Concrete, Stone & Masonry | 1 | 05-24-2012 10:45 PM |
| Stone Foundation 'Temporary' Repair... | Peter B. | Building & Construction | 17 | 12-16-2010 01:27 PM |
| Round House Foundation Feasibility | Mswick | Building & Construction | 23 | 02-27-2010 09:34 AM |
| Foundation Repair Help | rasilun | Remodeling | 1 | 10-15-2009 11:26 PM |
| How to add footing and foundation to existing foundation? | ptcamaro | Building & Construction | 6 | 06-22-2009 11:22 AM |
