Closing Up Garage Door - Do I Need A Footing? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-15-2013, 09:43 PM   #1
Closing up Garage Door - Do I Need a Footing?
Hi All,
I live in Rhode Island and have an attached garage. I'm closing up the garage door and putting in a window and normal exterior door instead. My question is regarding the area where the new wall will sit. Currently its pavement from the driveway. I'd like to cut out the pavement and poor a small footer of concrete the but up against the slab floor and act as a surface for the wall to sit on.
How deep do I need to make this go down? It's an existing structure and is also a gable end, so does it need to be the typical 48" a foundation or other footing would need to? Hope not!
bgagnon127 is offline   Reply With Quote
Old 01-15-2013, 09:50 PM   #2
Rewards Points: 12,796
Got a picture? Any garage I've ever build had fooring all the way around the whole building.
Old 01-15-2013, 10:05 PM   #3
Here's a rough sketch
Old 01-15-2013, 10:11 PM   #4
DIY staff
Rewards Points: 7,174
That should already have a footing --how old is the house?
Footing all around an attached garage have been required for a long time--
Old 01-15-2013, 10:21 PM   #5
Concrete & Masonry
Rewards Points: 468
Agreed, the foundation wall should already carry through underneath the driveway. It's not typical to have the driveway extend into the garage that far, but it is done at times for various reasons. If you remove that small section of driveway, you should find foundation underneath, and then you can pour a concrete patch over that. An elevated curb, up to the height of the existing concrete/block curb (assuming it has one) would be a good idea as well........
jomama45 is online now   Reply With Quote
Old 01-15-2013, 11:00 PM   #6
The House Was Built in 1956
Well here's to hoping that it does have the foundation underneath. Easy enough to find out. Thanks guys!
Old 01-15-2013, 11:59 PM   #7
747
registered
747's Avatar
Rewards Points: 534
I have a one car attached garage on my house. I turned it into a den. I just hired a carpenter and had him install a entry door with flanking transom(i don't think this is what there called.) An entry door with thin windows on both sides. Custom ordered. No digging necessary. Just bolted down to concrete. Not before he did a few things here and there for proper install. This was several years ago.
747 is offline   Reply With Quote
Old 01-25-2013, 08:11 AM   #8
GBrackins's Avatar
Rewards Points: 2,108
it may be a little late, here are the requirements in Rhode Island:
Building Code for One- and Two-Family Dwelling RI Amendments
2009 International Residential Code
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 07:42 PM
unconditioned garage reillyoevans HVAC 3 08-20-2011 07:29 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Changing Garage Door to 2FT less, footing question Daddioman Building & Construction 14 08-25-2009 06:59 AM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
