Close Half Basement Back Door With Concrete And Window - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-05-2013, 04:08 PM   #1
Close half basement back door with concrete and window
Hi members,
I see your help if fast and promising with other topics. Hopefully I will get some good suggestions to my planned project. We have a split house. Lower level is half way underground. We moved into house 5 years ago and never used the back door. We use patio door on back side of the house on middle level.
So, I want to remove the door and replace it with window to have some light in lower room. The question is how to better close the lower part. Should I just build wooden walls and pour with quickconrete mix?
Thank you,
Olex
Olex is offline   Reply With Quote
Old 10-05-2013, 04:14 PM   #2
Some photos of course
Not sure how to rotate them.
Filling in A basement window with Concrete brockmiera Building & Construction 7 09-03-2013 11:13 AM
Water Leakage Under Basement Window Well Slomarmoreno Plumbing 2 09-18-2012 05:40 PM
Frame out basement half wall diyinwi Remodeling 6 04-03-2012 09:08 PM
Basement Window in Concrete Masonry Wall Mike Mike Building & Construction 13 01-24-2012 01:58 PM
Need to determine proper Basement Window Header size- AdamH Building & Construction 1 11-23-2011 02:59 PM
