Cleaning Out Rust Blooms - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-11-2012, 11:30 AM   #1
Rewards Points: 290
Cleaning out Rust Blooms
Contractor used a angle grinder cutting up cast iron piping....
A tonnage of rust blooms appeared shortly after the 1st rain
I tried cleaning it with Oxalic Acid and PW. It made it 50% better but after the 2nd rainfall, it looks like they all came back
It did not do the trick..
I'm planing to give it another go this spring/summer.
Any suggestions or advice on cleaning out the CI rust shavings/blooms that are inherent in the concrete
mobiledynamics is offline   Reply With Quote
Old 05-11-2012, 04:11 PM   #2
Rewards Points: 582
Try a 6/1 water/phosphoric acid solution.
stuart45 is offline   Reply With Quote
Steel studs rust basement help bergerdude Building & Construction 17 10-02-2013 01:24 AM
In-Floor Swimming Pool Cleaning System Silkcityflorida Plumbing 0 03-22-2012 11:21 AM
can bad cleaning destroy your furnace eolsunder HVAC 1 09-22-2011 02:52 PM
Seeking advice on severe rust buildup issue. YerDugliness Plumbing 2 05-07-2010 06:02 AM
bathroom sink rust removal? bofusmosby Plumbing 4 11-12-2008 06:28 PM
