Cleaning Old Brick - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-11-2012, 07:44 PM   #1
Rewards Points: 1,062
Question
cleaning old brick
i am restoring a couple of old brick walls for exposure. 100 y.o. i have removed the old mortar joints with a grinder and a special blade and will tuckpoint new mortar. i have also cleaned the residue sand/mortar with a cup brush attachment for a grinder and they look beautiful.
since i know i will need cleaning them again after tuckpointing, i was wondering if i do it with muriatic acid to remove the residue from brick, can it damage the new mortar joints? or should i use TSP.
thanks
Old 08-12-2012, 10:52 AM   #2
Rewards Points: 502
Muriatic (Hydrochloric) acid is an efficient cleaner of mortar stains off brickwork. Safest compromise solution is about 10% with water.
Once the new mortar has set thoroughly, clean any residue by scrubbing on the solution with a bristle brush. You will see the stains froth up and gradually disappear. Persistent/heavy stains may need further applications.
Be careful because even a 10% solution will sting if it gets on your hands (use rubber gloves) and make sure it is washed off with plenty of water.
After drying out, the bricks may show some white salt deposit but this can be brushed off dry. Don't let it run on to other surfaces such as paintwork, glass or concrete.
Some older, soft bricks can be damaged by this stuff so best do a small test in an inconspicuous area first.
(not had any experience of TSP).
tony.g is offline   Reply With Quote
The Following User Says Thank You to tony.g For This Useful Post:
amakarevic (08-12-2012)
Old 08-12-2012, 01:42 PM   #3
i think white vinegar works for those white stains (the cheapest kind in the supermarket)
Old 08-12-2012, 03:54 PM   #4
biggles's Avatar
just caught a diy/hgtv rehab show and they were redoing a red brick interior. they did the acid water spray then used another brick rubbing...to have the acid work the bricks against each other...
Old 08-12-2012, 04:17 PM   #5
Rewards Points: 582
If you are carefull you won't need to clean them after repointing.
stuart45 is offline   Reply With Quote
Old 08-12-2012, 04:28 PM   #6
i am not careful. and if everything were perfect, i wouldn't need to ask questions in this forum.
Old 08-12-2012, 07:02 PM   #7
fragile old brick
I live in a brick house that was built in 1924 (Arizona). Pressure cleaning cannot be too harsh. After repairing missing grout, I found that Aldon products helped me tremendously and worked better than the muriatic acid that can be too harsh. In fact, if I had the workmen use proper Aldon product to begin with, the cleanup would have been a breeze and the ugly, dirty smudges would have come off easily. The bricks are soft fire kiln bricks made in 1923, so gentle is the word!
Dana Lynn is offline   Reply With Quote
Tags
tuckpointing
Cleaning newly laid brick rightit Concrete, Stone & Masonry 11 03-17-2012 11:04 PM
Fire Escape Painting / Brick Cleaning HudsonLetter Painting 0 07-19-2010 08:45 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Cleaning brick. Jim West Pa Building & Construction 12 09-23-2009 02:57 AM
Cleaning up /pointing brick troyce1 General DIY Discussions 4 02-28-2009 12:56 PM
