Cleaning Limestone Patio That Has Been Sealed - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-28-2013, 11:46 AM   #1
Cleaning limestone patio that has been sealed
We had a new limestone patio installed several months ago. I sealed the patio with 2 coats of DuPont™ StoneTech® Professional Heavy Duty Exterior Sealer. Water is repelled very well. However, when leaves and twigs lay on the patio and get wet, light brown stains are left. The stains do not rinse away easily with water, but I suspect a gentle scrubbing with a deck brush will do it.
My question is what is the best way to frequently clean the stone without affecting the sealer. Also, a homemade product that is gentle on the surrounding lawn and plants would be optimal. I was thinking of trying some dishsoap + warm water, but was hoping for some expert advice. I've attached 3 photos of the stone. The first two show the stains. The last one shows what the stone looks like under a covered area, and thus free of stains.
Thanks in advance!
Cleaning limestone patio that has been sealed-photo-1.jpg   Cleaning limestone patio that has been sealed-photo-2.jpg   Cleaning limestone patio that has been sealed-photo-3.jpg
sanbalto is offline   Reply With Quote
Old 09-28-2013, 05:25 PM   #2
Rewards Points: 4,454
we expect you're already well-versed in the following: http://www2.dupont.com/Stone_Tech_Pr...or_sealer.html
you're probably also aware of this: http://msds.dupont.com/msds/pdfs/EN/...3580547bef.pdf
this is the 1st time i've ever heard of a sealer having an expectant serviceable life of 5 - 10 yrs but i still believe in a belt AND suspenders,,, try some ' goof-off ',,, dawn dish detergent is an old stand-by, too,,, NEVER use soaps
Old 09-28-2013, 06:27 PM   #3
Thanks for the reply. I have seen the website info you posted, but they only recommend Dupont cleaner products that will likely be costly.
Wouldn't goof-off damage the solvent-based sealer?
You mention Dawn dish detergent, but say not to use soap. Am I missing something? Thanks!
Old 09-28-2013, 06:36 PM   #4
Rewards Points: 1,220
The obvious answer is to not let leaves lay on the deck. I am not familiar with that sealer, but if it allows such staining, it isn't very good. As for cleaning, anything that will remove the staining will also remove the sealer.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 09-29-2013, 05:24 AM   #5
if ' costly ' is the ' controlling authority ' [ algore, tnx for the phraseology ] - do i need to finish this thought ?
most know soaps are different than detergent but i can't speak for you
we use goof-off on ' CSS ' w/o damaging it & CSS is probably the best sealer avail w/o entering the polyurea/polyaspartic arena
New Patio Roof Construction ryanb4614 Building & Construction 7 07-16-2012 06:53 AM
HELP for simple patio and patio cover 1st time crzysprstr Building & Construction 8 05-29-2012 11:00 PM
In-Floor Swimming Pool Cleaning System Silkcityflorida Plumbing 0 03-22-2012 12:21 PM
want patio, water lines in the way CluelessnKansas Landscaping & Lawn Care 3 07-16-2010 10:53 PM
KNOWLEDGABLE condensate advice needed Nestor_Kelebay HVAC 5 11-23-2008 08:06 PM
