-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Cleaning limestone patio that has been sealed (http://www.diychatroom.com/f105/cleaning-limestone-patio-has-been-sealed-187745/)
sanbalto 09-28-2013 10:46 AM
3 Attachment(s)
We had a new limestone patio installed several months ago. I sealed the patio with 2 coats of DuPont™ StoneTech® Professional Heavy Duty Exterior Sealer. Water is repelled very well. However, when leaves and twigs lay on the patio and get wet, light brown stains are left. The stains do not rinse away easily with water, but I suspect a gentle scrubbing with a deck brush will do it.
My question is what is the best way to frequently clean the stone without affecting the sealer. Also, a homemade product that is gentle on the surrounding lawn and plants would be optimal. I was thinking of trying some dishsoap + warm water, but was hoping for some expert advice. I've attached 3 photos of the stone. The first two show the stains. The last one shows what the stone looks like under a covered area, and thus free of stains.
Thanks in advance!
stadry 09-28-2013 04:25 PM
we expect you're already well-versed in the following: http://www2.dupont.com/Stone_Tech_Pr...or_sealer.html
you're probably also aware of this: http://msds.dupont.com/msds/pdfs/EN/...3580547bef.pdf
this is the 1st time i've ever heard of a sealer having an expectant serviceable life of 5 - 10 yrs but i still believe in a belt AND suspenders,,, try some ' goof-off ',,, dawn dish detergent is an old stand-by, too,,, NEVER use soaps :no:
sanbalto 09-28-2013 05:27 PM
Thanks for the reply. I have seen the website info you posted, but they only recommend Dupont cleaner products that will likely be costly.
Wouldn't goof-off damage the solvent-based sealer?
You mention Dawn dish detergent, but say not to use soap. Am I missing something? Thanks!
Tscarborough 09-28-2013 05:36 PM
The obvious answer is to not let leaves lay on the deck. I am not familiar with that sealer, but if it allows such staining, it isn't very good. As for cleaning, anything that will remove the staining will also remove the sealer.
stadry 09-29-2013 04:24 AM
if ' costly ' is the ' controlling authority ' [ algore, tnx for the phraseology ] - do i need to finish this thought ? :whistling2:
most know soaps are different than detergent but i can't speak for you :huh:
we use goof-off on ' CSS ' w/o damaging it & CSS is probably the best sealer avail w/o entering the polyurea/polyaspartic arena
