Cleaning Garage Floor - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-01-2013, 10:22 PM   #1
Rewards Points: 1,088
cleaning garage floor
What's the best method to remove oil that soaked into a concrete garage floor? I heard muriatic acid, although I heard what HD sells is too weak.
handy man88 is offline   Reply With Quote
Old 10-01-2013, 11:36 PM   #2
K&B Designer
Live_Oak's Avatar
The best way is to prevent it by an epoxy coating. Too late for that!
Try a detergent cleaner like Dawn first. Then do a poultice of 1/2 baking soda and 1/2 baby powder moistened with acetone into a paste. Cover the stain, and then with plastic and tape in place.
Do NOT use muriatic acid. First of all, it's extremely dangerous to handle without the proper personal protective equipment. It eats holes in things, and will etch your concrete. Etching isn't cleaning. It's tons of microscopic holes that have been eaten into the concrete.
Live_Oak is offline   Reply With Quote
The Following User Says Thank You to Live_Oak For This Useful Post:
Old 10-02-2013, 03:54 AM   #3
Rewards Points: 4,538
remember what he said, detergent, NOT soap another method is, again, poultice ( that's mixing up a paste if you're not aware of the definition ) of vm&p naptha + diatomaceous earth ( fuller's earth ) which you can pick up from any apron/vest & swimming pool co respectively
muriatic's a no-no just like he said
How to stop water coming up through a garage floor ADaniLion General DIY Discussions 5 07-16-2013 03:31 PM
adding second floor to garage ronle Building & Construction 7 04-29-2013 07:24 PM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 07:42 PM
Settlement under Garage Floor taadz Building & Construction 10 08-30-2012 09:58 PM
Garage floor coatings? cbzdel Painting 7 05-21-2010 06:46 PM
