Cleaning Brick - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-25-2012, 07:44 PM   #1
Cleaning brick
Hi to all.
I bought an old brick house that has white aluminum fascia paint bleeding down onto the red brick in a bunch of spots. I have not tried to clean it yet, but just wondering what I should use to clean it up?
spacoli is offline   Reply With Quote
Old 02-25-2012, 09:58 PM   #2
Missouri Bound's Avatar
Try a power washer with a turbo tip.
Do you want it your way or the right way?
Old 02-25-2012, 10:04 PM   #3
Rewards Points: 12,876
And think about having that old trim changed to PVC trim coil. It will not chaulk like that old stuff does.
Old 02-26-2012, 07:49 AM   #4
Thanks Guys
I was planning on changing the fascia with new. I figured it was just a poor quality paint on some of the coil stock used. You can see the difference where the bad stuff was used and where the better quality stuff was used (no bleeding).
I was worried about using a power washer removing the mortar. It looks like it was re- pointed at one time and I can see it's falling out in spots.
I'm guessing it's going to be tough removing by hand with some type of cleaner?
Old 02-26-2012, 10:20 AM   #5
Ravenworks's Avatar
I use "Sure Kleen" your best bet would be going to a local brick supplier and asking them.
Ravenworks is offline   Reply With Quote
Fire Escape Painting / Brick Cleaning HudsonLetter Painting 0 07-19-2010 08:45 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Cleaning brick. Jim West Pa Building & Construction 12 09-23-2009 02:57 AM
Bad Bad Paint job to fix. Cleaning brick overspray and other problems. (Pics) ewheatley Painting 1 05-19-2009 02:08 PM
Cleaning up /pointing brick troyce1 General DIY Discussions 4 02-28-2009 12:56 PM
