Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-25-2013, 12:45 PM   #1
cinder block basement issues
hello all. new guy here. might as well make my first post a good one! i am wondering what to do about my cinder block wall on the outside of it. it has parging on it and it looks like moisture is coming out of it at the mortar joints. it is really ugly looking from the street and we want to put real stone systems stone veneer on, but i need to correct this problem first. a little backround on the house. it was built in 78 and has had an unfinished basement up till we moved in in 09. i watched first for any signs of water coming in. we live in a very sandy area with an aquafir under us so the water goes away real fast. no moisture in the basement. in '11 i insulated the basement so far with 2" of xps. still have yet to finish with walls and roxul batts.
the problem on the outside looks to have gotten a little worse during the winter. the lines showing through are also there in the summer. i am hoping it was just a bad parging job but not sure. i have searched the net high and low but i cant find anything similar to what i have. here are a couple pics of what i mean.
thanks for the help
clarence
69charged is offline   Reply With Quote
Old 03-02-2013, 06:48 AM   #2
can't tell IF some parging's lossen'd & fallen off it was done in a ' slop trowel ' texture,,, either way, this is what i'd do,,,,,,,,,,,,,,,
1, pressure wash ( 3,500psi, 4gal min, turbo nozzle ); 2, spray on 2 coats of silicone siloxane water repellent; 3, mechanically attach expand'd wire mesh; 4, trowel on mortar & attach faux stone.
IF some questions rais'd above could be answer'd, reserve right to change answer
ps - most everyone lives above an aquifer
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 09:26 AM
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 08:03 AM
Wire through cinder block drjay9051 Electrical 1 12-07-2010 01:42 PM
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 35 10-28-2010 03:01 AM
Basement wall issues. Need rough idead of fix. meltdowndave Building & Construction 6 10-03-2009 12:24 PM
