Cinder Block - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-06-2015, 10:13 AM   #1
Rewards Points: 4
Cinder Block
Does anyone know an easy inexpensive way to cover exposed cinder block foundation?
ffemt is offline   Reply With Quote
Old 05-06-2015, 10:32 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 824
Paint.
Are you talking about wanting to cover it with siding or stucco?
Old 05-06-2015, 10:37 AM   #3
Rewards Points: 4
Our subdivision says that we can't have any exposed cinder block. I was going to use manufactured stone to cover it but that would cost $10,000 or more.
I was trying to find a paint or something else to use that would cover it well and be pretty easy to do.
Old 05-06-2015, 08:11 PM   #4
Rewards Points: 824
You could put a parge coat on it prior to painting it. That is if you want the surface to be smooth.
Old 05-07-2015, 05:49 AM   #5
Rewards Points: 4,440
maybe a couple coats of block filler would camouflage/disguise it to the hoa's satisfaction
Old 05-07-2015, 09:21 AM   #6
Rewards Points: 2,600
what does the HOA allow as an exposed surface? stucco?
concrete_joe is offline   Reply With Quote
Old 05-07-2015, 12:03 PM   #7
concretemasonry's Avatar
Rewards Points: 2,566
Two coats of Thoroseal brushed on (in a two day period for effectiveness) will do a good job of hiding the mortar joint pattern and shadows in most cases (also makes a durable water-resistant cover) and the second coat can be white. Hard work if you do it right.
This usually meets most regulations, unless they are written to mean a brick surface.
Dick
concretemasonry is online now   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
stadry (05-07-2015)
Water pipe to house. Do I check under cinder block ???? steve3847 Plumbing 10 12-29-2013 08:50 PM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 01:26 PM
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 08:03 AM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-06-2009 12:02 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
