Chopping Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-24-2013, 06:27 PM   #1
Rewards Points: 878
Chopping Concrete
I have to chop a 3' long by about 5" wide chase. I need to be careful because the concrete I'm chopping is only about 10" wide. What is the best tool for this. Hopefully something I can rent form HD. THanks.
Mstrlucky74 is offline   Reply With Quote
Old 10-24-2013, 06:42 PM   #2
Rewards Points: 14,306
Got a picture?
Not a good thing.
Your going to really weaken what's still there.
Any idea on how thick it is? A hammer drill to drill a test hole would be nice.
Old 10-24-2013, 06:55 PM   #3
Rewards Points: 878
We need to remove this piece of baseboard and my plumber is going to cut it out and run a pipe right next to where you see the baseboard.
Old 10-25-2013, 03:55 AM   #4
Rewards Points: 4,796
didn't say how deep this chase has to be,,, we cut 1" deep w/4" grinders,,, perhaps you can rent them from apron/vest stores but they're not much if you can't,,, buy diamond blades there OR thru ebay ($ 3 ea ),,, make a series of cuts 1/2 OR 3/8"" apart & parallel then chip off the remaining conc - easiest way i know
caution - its dusty work & will probably be illegal someday if epa & other like-minded weenies have their way
Old 10-25-2013, 04:26 AM   #5
Rewards Points: 878
Thanks a lot!!! About 2"
Old 10-25-2013, 04:34 AM   #6
walk in the park get a decent vac to suck up dust while sawing,,, chipping off the ' fins 'won't make near as much dust
The Following User Says Thank You to stadry For This Useful Post:
oh'mike (10-25-2013)
Old 10-25-2013, 05:24 PM   #7
Rewards Points: 878
What do you mean chipping of the fins? We are gonna cut the baseboard at each end and then he is just gonna connect a pipe in the concrete were the baseboard run was because now that is an entrance into a room. The pipe has to be moved over a little because now it is run over the tile. He is gonna add some fittings etc.
A grinder is still the best bet?
Old 10-25-2013, 06:34 PM   #8
scrolling up will refresh your memory w/the diamond blade kerf method,,, what's left 'tween the sawcuts are call'd ' fins ',,, you can probably remove them easily w/brick chisel & framing hammer.
when working in the city sawing/coring/drilling/conc demo, the 4" grinder was used frequently,,, is it the best ? i have no idea but we did that work for a living
you could just make 1 sawcut 5" w X 2" deep IF you could find the blade OR stack 'em together similar to a hgwy grinder,,, unfortunately, it would take mighty joe young helping king kong to handle the torque of the saw
Old 10-25-2013, 06:40 PM   #9
Rewards Points: 878
Lol.... Thanks
Old 10-28-2013, 12:07 PM   #10
Rewards Points: 878
Thanks so much guys...I did it. WOW WAS IT DUSTY. My wife was snapping...lol. Dust went to the 2nd floor and covered everything..
Old 10-28-2013, 02:37 PM   #11
evidently you forgot this part [ ' get a decent vac to suck up dust while sawing ' ]
Old 10-28-2013, 02:43 PM   #12
Rewards Points: 878
I do have one...I did not see you wrote that....
Old 10-28-2013, 03:34 PM   #13
concretemasonry's Avatar
Rewards Points: 2,642
Look at post #6.
Dick
concretemasonry is offline   Reply With Quote
Old 10-28-2013, 03:49 PM   #14
Rewards Points: 878
Originally Posted by concretemasonry View Post
Look at post #6.
Dick
I know.....I see now.
Old 10-28-2013, 07:20 PM   #15
oy ver is mere next time read AND heed
Gap in concrete by corner of garage door jamb, intentional or not? daluu Concrete, Stone & Masonry 1 09-16-2012 05:23 PM
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
