Chimney Reline With Hvac Spiral Ducting - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-10-2013, 06:49 AM   #1
chimney reline with hvac spiral ducting
I am looking into doing a chimney reline for wood stove insert. Have not been real hot on what is available, most of the flex duct is .oo6 thick.
Came across commercial HVAC spiral ducting, galvanized 26 gauge steel.
could that be used to do the reline. insulating with dry insulating mix.
any reason not to use, seems much stronger that what I am finding
for use.....
bobmorris61 is offline   Reply With Quote
Old 01-10-2013, 10:28 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 628
Ayuh,.... You need a chimney liner, or smoke piping,...
Hot air ductin', is Not what ya need....
The Following 2 Users Say Thank You to Bondo For This Useful Post:
bobmorris61 (01-17-2013), concretemasonry (01-10-2013)
Old 01-11-2013, 08:01 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Flue gases contain some nasty, acidic stuff mixed with water vapor. Galvanized coating is not going to like the heat or that acidic mix. Once it burns away, the plain steel underneath won't last long. Stainless will stand the heat and resist the acids in the soot and smoke.
The Following 2 Users Say Thank You to Maintenance 6 For This Useful Post:
How to install chimney liner Rockford How To Guides 3 07-16-2012 05:15 PM
Why a Chimney Liner? Rockford HVAC 0 07-12-2012 11:03 AM
rerouting HVAC ducting for an upflow furnace joregon3597 HVAC 2 05-03-2012 08:08 PM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 11:00 AM
HVAC install from last year, Help with Chimney, lost closets coderguy HVAC 5 10-30-2011 12:26 AM
