Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-17-2012, 09:24 AM   #1
Chimney rebuild : chimney liners :types
I have a chimney being rebuilt that has 3 flues and one
needs a gas liner for a furnace(NTI high efficiency boiler that is 5 years old). and the other 2 liners are for 2 wood burning fireplaces that are not presently in use and may just be capped for now.
My fireplaces are currently old coal burning fireplaces.
Anne
thomsoa is offline   Reply With Quote
Old 07-26-2012, 04:50 PM   #2
RockfordChimney
Anne,
You can use the same type of liner for both the gas furnace and also for the wood burning fireplaces. The flexible stainless steel 316ti liner works for wood, gas, oil, pellet or coal type of fuel. A flexible liner will be easier and less expensive to install than a rigid liner. Depending on the height, roof pitch and your ability, a liner can be installed in as little as 3 hours.
Rockford is offline   Reply With Quote
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 11:00 AM
chimney: repoint or rebuild? wombosi Building & Construction 11 10-10-2011 03:44 AM
Tuck point or rebuild chimney? jane99 Building & Construction 2 05-18-2010 02:12 PM
fireplace and chimney top rebuild??? syborg Building & Construction 18 01-16-2010 03:58 PM
Chimney repair: rebuild or repoint? cloud9 Building & Construction 33 09-22-2009 10:12 PM
