Chimney Insulation - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-17-2014, 03:06 PM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Chimney insulation
My chimney goes thru the middle of my house. Right where my chimney joins my ceiling, on one side, I've noticed a dark yellow build-up. I painted over it and in two days it was back. I went in the attic and noticed metal flashing type of material running around the brick chimney, parallel to the ceiling. That metal strip had the same type of build-up on it but just a little. No obvious wet spots on chimney. The chimney was partialy covered with un faced fiberglass insulation. I put that back and also stuffed some into the two inch space above that metal strip. I then went up to the roof and found no obvious leaking source, but noticed my chimney cap was covered with a black rubber type material, with a few holes (small) in it. What do you think is the cause of the dark yellow build-up on my ceiling??
Should I wash the area with TSP and replace the pop corn type material and ttry to paint again??
Any suggestions
Thanks Barry
Barry J is offline   Reply With Quote
Old 01-17-2014, 05:42 PM   #2
Rewards Points: 13,450
Anyone in the house smoke of do you burn candles?
I'm just guessing the air leak may be acting like chimney and sucking dirty air into the attic. When the warm air hit the colder metal the moisture condenses and more dirt sticks to it.
It's called ghosting.
Old 01-17-2014, 05:45 PM   #3
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Nobody smokes, we do burn candles but not that often
Old 01-17-2014, 05:53 PM   #4
http://inspectapedia.com/interiors/ThermalTracking.htm
Old 01-17-2014, 07:22 PM   #5
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
The area is more yellowish
Here is what it looks like
Old 01-18-2014, 11:16 AM   #6
Rewards Points: 582
Could be Hygroscopic salts.
http://www.dynamicpropertycare.com/s...3f9d5b29095ca8
stuart45 is offline   Reply With Quote
Old 01-18-2014, 03:25 PM   #7
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
How should I fix it, wrap the chimney better with insulation down to that metal strip, patch any hole on the outside of the chimney??
Old 01-18-2014, 05:36 PM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,092
What is the chimney flashing like on the roof side condition wise?
Also, is the chimney sealed tight where it penetrates the ceiling? Warm moist air hitting that cold metal = condensation.
The metal in the attic should be air tight as well so as to prevent the moisture carried in the air from reaching the attic air.
Old 01-20-2014, 07:18 AM   #9
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
The outside flashing looks good,
How should I seal it, I've noticed a slight space where the ceiling and chimney meet, should I use chaulking from the inside ceiling?
Old 01-22-2014, 08:28 AM   #10
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Should I seal from the attic or ceiling??? In the attic I can't use "Great Stuff" near the chimney correct??
Colonial Split level drew7ster Insulation 11 01-09-2013 03:44 PM
Chimney Rattles/Sways in Windy Weather cprice12 Concrete, Stone & Masonry 10 09-28-2012 10:36 PM
Chimney Liner Insulation Rockford Insulation 2 08-13-2012 09:22 AM
Chimney liner insulation Rockford HVAC 0 08-07-2012 08:38 AM
Insulation Around Chimney myfirstrodeo Insulation 2 07-19-2012 12:44 PM
