-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Chimney Flue pipe question (http://www.diychatroom.com/f105/chimney-flue-pipe-question-160847/)
DougDA 10-22-2012 02:57 PM
Just moved into this house this past July...and noted that the masonry chimney had been capped/sealed for ventless gas logs.
Preferring real wood fires, I uncapped it and noted that the flue pipe liner is it really good condition, but that there seems to have never been the last section of clay flue pipe which would normally extend the 2 to 3" about the crown.
It doesnt appear as though it was ever there (i.e. the inside of the last section of pipe is blended into the crown)....
so my question is; is it necessary to widen the opening to fit a new section in just to extend it up?
(I can snap a picture this evening)
joecaption 10-22-2012 03:04 PM
Get a real chimmney sweep to come look it over.
Ever had a real wood burning fireplace before?
Least efficient way to try and heat there is.
The bugs, dust, soot, cost of wood, sucks the heat out of the other rooms.
DougDA 10-22-2012 03:22 PM
yeah...I grew up with a real wood fireplace. and living in the southeast, heating is not really a problem. its more about a real wood fire than anything else.
joecaption 10-22-2012 03:29 PM
Get the same look with a vented gas fire place, but no mess and real usable heat comes out of it.
jdherville 10-22-2012 06:44 PM
shoo natural gas promoting pests...
Are you going to use it as an open fire or enclosed wood stove? If you have a cylindrical flue pipe there already I'd suggest to go enclosed. It can be very difficult to get good efficiency/ optimum heat from an open log fire. If there is room the best is a free standing stove you can cook or heat water on. If not, enclosed. With a wet back you have the ultimate. Wood is still more sustainable and an overall more sensible fuel choice than natural gas so good on you. In most cases you should be able to insert an extension piece to the flue without an issue. I would also suggest looking at some of the newer anti down draught/ negative pressure cowls on the market. blowback is still a serious overlooked issue causing a lot of grief to people due to EPA/ HPBA and the testing regime's sole focus on the firebox. Fixing the performance with the right top can improve inversion emissions issues significantly too. No fans/ replacible catalytics or filters should be necessary either.
