Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-09-2012, 08:48 PM   #1
chimney flashing
Can i use lead counter flashing and aluminum base flashing for chimney?
greg112975 is offline   Reply With Quote
Old 04-09-2012, 08:56 PM   #2
chimney flashing
You can but where you going to find it?
Old 04-09-2012, 09:18 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
chimney flashing
Yes, you can.
- Build Well -
Old 04-09-2012, 09:32 PM   #4
chimney flashing
First off, I am not sure I understand what your comment is referring to, or your specific point.
However, to address; The "raw materials" can be found at any Big Box Store and Masonry Supply House. You don't actually buy "chimney flashing" per say. What you do is obtain the necessary metallic materials (including any needed brick, mortar, and sealants), then haul it to the (safely staged) rooftop location, fabricate the flashing components (that make up the necessary flashing system) onsite = and install per spec:
Example: http://www.ehow.com/how_12217892_lead-chimney.html
Diagram: http://brooksideroofing.ca/Chimney-Flashing.jpg
Hope this helps (unless I misunderstood your statement).....
- Build Well -
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 11:00 AM
Stucco and Flashing at Base of Chimney Need Repair vcheez Roofing 15 11-10-2011 06:39 PM
Need help deciding giving this chimney flashing contractor a second chance tracyj Roofing 3 03-29-2011 10:56 AM
Bad job replacing chimney flashing? TNVolFamily Roofing 12 02-28-2010 08:04 PM
Chimney Flashing mfitzsimons Roofing 4 04-20-2009 11:00 PM
