Chimney Crown - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-26-2013, 03:00 AM   #1
MarginallyQualified
Rewards Points: 2,464
Chimney Crown
Two of the three clay flue liners were set too low...
they're flush with a too thin mortar crown.
What are the gotcha's to look out for with having the
top course of (50year old) brick removed in order to
provide enough depth for a proper crown?
The liners and caps come afterward.
Thanks.
Old 12-26-2013, 08:11 AM   #2
Rewards Points: 104
I am not an expert in this field, but, assuming that it drafts properly, your solution sounds reasonable, to me. Before going there though, I would want to make sure that the existing flue height is in compliance. Again though, not an expert here, so although I am fairly certain of what code is in my area, I will leave it up to someone else to comment on, or you could check your local code yourself. And I am fairly certain that this can vary, depending on whether or not you are burning wood, so you may want to post the fuel source. After that, you want to use concrete, not mortar, allowing for at least 2" thick, sloped away from the flue, and with at least 1-1/2" to 2" overhang beyond the brick. I like to slope the bottom of the concrete that overhangs the brick as well, or otherwise incorporate a detail that causes water to break at the outside edge, as opposed to maintaining surface tension and running back to the brick.
Old 12-26-2013, 10:08 AM   #3
Rewards Points: 1,232
It would be easier (and acceptable) to add more flue tile than to remove brick.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 12-26-2013, 01:11 PM   #4
MarginallyQualified
hmmm...
For some reason that didn't seem possible earlier as I don't think I need more than what the caps require to be installed on.
With what I have now only the center of three clay liners
is higher than the too low crown ---___---| |---___---
That center flue is getting blocked off.
How much liner should be added to the other two above flush?
Are the tiles easy enough to cut clean (with proper tools)?
Old 12-26-2013, 01:59 PM   #5
Rewards Points: 13,694
A ciruler saw with a diamond blade will cut them any length you want.
The more the better.
I'd cut them at least 6" long.
TarheelTerp (12-26-2013)
Old 12-27-2013, 02:16 PM   #6
They can be as high as you want, but there needs to be 4" difference between the heights at a minimum. Normal flue tiles are 12" or 24", so get a 12" and cut it into an 8" and a 4".
How to install chimney liner Rockford How To Guides 3 07-16-2012 04:15 PM
Why a Chimney Liner? Rockford HVAC 0 07-12-2012 10:03 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
Water leak around chimney crown. desert-rat Building & Construction 2 12-27-2010 09:49 PM
Installing a new chimney crown ikessky Building & Construction 3 09-12-2010 09:54 PM
