Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-17-2012, 08:41 AM   #1
Chimney Chase Replacement
Some advice pease.
I have a cinder block wall/chimney with a galvanized steel chimney chase cap on top. It was poorly installed and looks like it is rusting. I am looking to get it replaced and have been offered a couple options. 1. Replace it with a stainless steel cap or 2. pour a concrete cap over the existing cap and seal it that way. I am trending toward the cement since it is significantly cheapr but have not heard of doing this. Also, they say they cannot cut the flute as that will void the fire warranty so installing a custom cap may be more difficult. Any ideas/advice on this problem?
sewert1 is offline   Reply With Quote
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 11:00 AM
chimney chase leaks into attic dadscady Roofing 16 10-08-2010 04:04 PM
Decorative chase for masonry chimney and radon vent? Badfish740 Building & Construction 1 05-03-2010 07:51 PM
Sealing chimney chase(?) cbrc5eric Building & Construction 3 03-15-2010 10:31 AM
Exterior chimney chase bronco2 Building & Construction 3 09-22-2009 02:26 PM
