Chimney Cap - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-10-2013, 08:44 AM   #1
Amateuralex's Avatar
Rewards Points: 270
chimney cap
Our roofer told us we need chimney caps. On one of our two chimneys, some of the brick near the top is chipping off a little bit. Apparently that's from water getting in and freezing?
My understanding is that a chimney cap consists of a metal hood for the chimney as well as a concrete/mortar cap that is sculpted to divert water away from the chimney.
It's an older house, and I have to assume it had one there, so the job will involve chipping away the old mortar etc?
I am getting some quotes so I wanted to get educated before they come out. Am I understanding things properly? Any more advice?
Amateuralex is offline   Reply With Quote
Old 04-10-2013, 09:01 AM   #2
Rewards Points: 12,858
Got a picture of what you have now?
If you have a clay tile liner the cap just slides over tile and is held in place with 4, screws.
The crown is just some morter mix.
Same with the tuck pointing to fix the bricks.
Old 04-10-2013, 09:25 AM   #3
Rewards Points: 270
It's actually pretty high up above the roof and I am not good at getting up there. Which is why I am getting quotes, but it of course makes me a bit uneasy that I can't see it.
Thanks for the advice. I am getting 3 quotes, I guess I'll just see what these guys say that I need.
I just googled 'tuck pointing' so now I know what that means!
Old 04-10-2013, 11:23 PM   #4
Concrete & Masonry
Rewards Points: 470
The crown is not "just some mortar mix", unless of course you want to replace the crown every few years. This kind of mentality is why so many chimneys fail.
A decent chimney cap/crown is cast concrete, and will have at least 1.5" overhang over the brick veneer, more is better.
More than you'll ever want to know about the subject:
http://www.masonryconstruction.com/I...68-1375172.pdf
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Old 04-11-2013, 08:32 AM   #5
Rewards Points: 270
Wow that's helpful!!! Thanks so much. Now I know what to expect of whoever I hire and I can ask the right questions!
How to install chimney liner Rockford How To Guides 3 07-16-2012 05:15 PM
Why a Chimney Liner? Rockford HVAC 0 07-12-2012 11:03 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 11:00 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 04:12 PM
