Chemstone Patio Removal - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree2Likes
  • 1 Post By Canarywood1
  • 1 Post By Bondo
Old 01-11-2017, 02:14 PM   #1
Rewards Points: 62
Chemstone patio removal
Is there any recommendation for the removal of a chemist one finish on a patio? Probably 20 plus years old.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is online now   Reply With Quote
Old 01-11-2017, 05:25 PM   #2
Rewards Points: 4,648
Re: Chemstone patio removal
is this what you mean ? http://elitecrete.com/wp-content/upl...tive-Stain.pdf
chenstone's a trademarked product - acid stain for concrete
stadry is online now   Reply With Quote
Old 01-11-2017, 05:38 PM   #3
Rewards Points: 62
No its a finish from the 60-70's, its a gravel finish that is on top of the actual patio.
Old 01-11-2017, 09:36 PM   #4
Msradell's Avatar
Rewards Points: 210
Can you give us a picture of it so we know what you're talking about?
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 01-11-2017, 09:39 PM   #5
Rewards Points: 62
I'll take one tomorrow and post.
Old 01-12-2017, 05:54 AM   #6
chattahoochie ? does the finish appear to have lots of small pebbles or graded aggregate in the surface ? as noted, pics are a must !
Old 01-12-2017, 06:01 AM   #7
Rewards Points: 62
Yes, small gravel or aggregate exposed.
Old 01-12-2017, 02:44 PM   #8
Rewards Points: 62
See attached
Old 01-12-2017, 07:15 PM   #9
Rewards Points: 3,626
Looks like that poly pebble stuff, only way i've seen it removed was with an air or electric hammer with a spade bit, was coming up pretty good though.
Msradell likes this.
Canarywood1 is online now   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
digitalplumber (01-12-2017)
Old 01-13-2017, 03:51 PM   #10
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,354
Ayuh,..... What do ya plan to put back down,..??
It's gonna need some hiding power,....
Even with a spade bit, there's gonna be scars,....
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
digitalplumber (01-13-2017)
Old 01-16-2017, 10:53 AM   #11
our local apron store is carrying 'cementall' - an excellent consideration to replace the present coating,,, product life depends largely on proper surface prep,,, it can be colored to your choice, trowel/squeegee finish, & can be applied either w/trowel, squeege, or gauge rake
The Following User Says Thank You to stadry For This Useful Post:
digitalplumber (01-16-2017)
Patio with small retaining wall details.. freeclimbmtb Concrete, Stone & Masonry 0 08-08-2014 11:49 AM
Concrete Patio Removal millsteg Concrete, Stone & Masonry 33 02-08-2014 06:38 AM
Transition from a new pitched patio to an existing level patio barlav Concrete, Stone & Masonry 1 05-03-2013 05:20 AM
how to transform concrete patio into deck IsabellaS Landscaping & Lawn Care 5 07-04-2012 07:41 PM
removal of 4x4's in patio concrete Mustanger151 Building & Construction 2 05-12-2009 06:55 AM
