Channel In Slab - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-08-2012, 01:56 PM   #1
channel in slab
I had to cut a 3" deep channel in the slab to route power to the new kitchen island. After putting the conduit in- I refilled channel with concrete- Since the concrete does not really give me a nice "level" surface back to the top of the existing slab- What can I put there to make it smoother? Just some type of leveler?
skinut2234 is offline   Reply With Quote
Old 10-08-2012, 03:23 PM   #2
Rewards Points: 3,398
Since concrete is not self leveling,it's up to you to make it level and smooth when you replaced it.
Canarywood1 is offline   Reply With Quote
Extending Patio Slab and adding a cover Jeoroc24 Building & Construction 5 04-12-2011 12:16 PM
raised slab foundation tclark Building & Construction 6 01-07-2011 09:10 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
Making a channel in a post tension slab firehead67 Building & Construction 11 08-22-2009 02:38 PM
