-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Changing mortar color? (http://www.diychatroom.com/f105/changing-mortar-color-5411/)
kcrossley2 12-17-2006 12:36 AM
3 Attachment(s)
I have an interesting situation that I need some help with. I'm purchasing a brand new home from a track home builder. The finished home is going to be vinyl sided with a brick foundation. The brick I selected is Silas Towne from Nash Brick, which is sort of a random brown brick.
Okay, here's where it gets a little silly. When I signed the contract several months ago I asked the builder to use straw mortar, since I felt it matched the Silas Towne color better. At that time I was told that they had to use gray mortar since the house I was buying was vinyl sided. The only way I could get straw mortar was if I purchased a full brick faced home, which I was perfectly willing to do. Unfortunately, this builder doesn't allow two houses next to one another to have the same brick or siding color and my future next door neighbor already selected Silas Towne.
Anyway, I didn't think much of this until I visted the homesite today and saw the finished brick. As it turns out the masonry contractor mistakenly used straw mortar for the front porch and gray for the rest of the foundation. Personally, I like the straw color but it's against their color policy. BTW, the first picture shows gray mortar to the left of the corner and straw to the right. Second picture is all straw. Third picture is all gray.
So here's my question. Is there anyway I can tint or color the gray mortar to match the straw color I like? If so, how is this done and how permanent is the coloring?
Thanks,
Kelly
clasact 12-17-2006 05:52 AM
I am pretty sure you could use concret stain to tint it although to just do the motor at this point it going to take awhile and alot of patience or you could stain the whole thing to match the other brick
kcrossley2 12-17-2006 12:00 PM
How permanent is concrete stain and what brands do you recommend? I'm trying to avoid a maintenance problem.
Tscarborough 12-17-2006 03:29 PM
There is no DIY way to fix it. There are two ways to change the color of the mortar permanantly with no future maintainance issues:
You can cut out the joints and tuckpoint them.
You can hire a company that does brick/joint staining and they can make the joints (and the brick) look like whatever you want.
Neither solution is cheap or easy.
kcrossley2 12-17-2006 03:53 PM
Why do you think they used straw for the porch and gray for the balance of the foundation? That just doesn't seem to make much sense.
kcrossley2 12-17-2006 03:55 PM
How much do you think tinting the mortar costs?
Tscarborough 12-17-2006 04:01 PM
About half of what it would cost to tear it out and redo it.
kcrossley2 12-17-2006 04:03 PM
Is tinting the mortar something most brick masons can do or is it a specialized process?
Tscarborough 12-17-2006 04:07 PM
Your terminology is incorrect. You tint the mortar when it is plastic. After it is laid, you are staining the mortar.
Most masons can tint mortar, very few can stain it, although most can tuckpoint it.
kcrossley2 12-17-2006 04:37 PM
Oops! Sorry. Okay, what's tuckpoint?
Tscarborough 12-17-2006 04:50 PM
You grind out the joints to a depth of 3/8" to 1/2" and replace the mortar with fresh.
kcrossley2 12-17-2006 04:55 PM
That sounds like a PITA. Are you sure staining wouldn't be cheaper?
Tscarborough 12-17-2006 05:15 PM
Almost all masons can tuckpoint, only a few nationwide provide the service (to an acceptable extent) of staining. Which do you think is cheaper?
kcrossley2 12-17-2006 05:25 PM
Well since the mason mixed the mortar colors (gray for the porch, and straw for the rest of the foundation), do you think asking them to tuckpoint ONLY the front foundation of the house is a reasonable solution?
Tscarborough 12-17-2006 05:30 PM
Will you be landscaping the home? If so, you are back to that same 99% who will never notice.
If you want to fix it yourself, there is an alternative that you can do that will last long enough for it not to matter (because of normal grime accumulation on a foundation). You can mix a slurry of cement, bonding agent, and pigment to the desired color and and scrub it into the joints. Not a recommended practice, but it does work.
