Ceramic Tile - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-06-2013, 01:55 PM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 226
Ceramic tile
I'm attempting to drill thru what I believe is ceramic tile in my kitchen, I have brand new carbide tip drill bits. I have been drilling one hole for about 20 minutes now and have gotten only what appears to be half way thru,,,,,
,,,,Am I missing something???
Am I doing something wrong or fo I just have tough thick tiles
Barry
Barry J is offline   Reply With Quote
Old 10-06-2013, 02:35 PM   #2
Rewards Points: 12,824
How big a hole?
Using a hammer drill?
Old 10-06-2013, 02:59 PM   #3
DIY Homeowner
Barry J's Avatar
Rewards Points: 226
3/16 hole....using reg power drill, first hole is thru aft 45 minutes...second hole bout 1/3 of the way thru
Old 10-06-2013, 03:08 PM   #4
Ceramic tile is best with a hammer drill and carbide or diamond bit and regular drill with a little water to cool as you go. Don't buy cheap bits for this
robs660 is offline   Reply With Quote
Old 10-06-2013, 03:29 PM   #5
DIY Homeowner
Barry J's Avatar
Rewards Points: 226
Should I go small all the way thru, the go big to widen the hole???
Old 10-06-2013, 03:31 PM   #6
DIY Homeowner
Barry J's Avatar
Rewards Points: 226
Go at different angles or stay at same straight angle
Old 10-06-2013, 03:48 PM   #7
A hammer drill would have drill it in about 30 sec. or less.
Old 10-06-2013, 03:59 PM   #8
DIY Homeowner
Barry J's Avatar
Rewards Points: 226
Yeah, but don't got one!!
Old 10-06-2013, 06:02 PM   #9
DIY staff
Rewards Points: 7,174
No hammer drill? Then switch to a diamond coring bit----use water to cool and lubricate---about a minute per hole---
I buy them on Ebay---but a local tile store should have them--
oh'mike is online now   Reply With Quote
Old 10-06-2013, 07:23 PM   #10
DIY Homeowner
Barry J's Avatar
Rewards Points: 226
All done, not bad an hour a hole. Used the water trick also.
Will be asking santa for a hammer drill this year
Thanks for the help
Barry
The Following User Says Thank You to Barry J For This Useful Post:
oh'mike (10-09-2013)
Old 10-06-2013, 09:43 PM   #11
Rewards Points: 142
i hammer drilled a few holes here. at first it was taking forever. i got pissed, and put some real weight into it. the holes drilled fast then. so perhaps you were not pushing hard enough.
Fix'n it is offline   Reply With Quote
Retrofit ceramic tile corner shelf in shower jgibbs Tiling, ceramics, marble 4 06-07-2012 12:29 PM
ceramic tile stain kivy Flooring 10 04-09-2012 07:57 AM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 08:48 PM
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 11:42 PM
Replacing Ceramic tile floor handy andy Flooring 4 03-28-2011 01:07 AM
