Cement Slab Moisture Proof? - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-06-2013, 01:09 AM   #16
Rewards Points: 582
Originally Posted by itsreallyconc View Post
http://www.masticasphaltcouncil.co.u...ations/floors/ - stuart, is that hot-applied rubberized asphalt cement ? that's not a common process here in the colonies as it calls for a double boiler [ indirectly heated ] to properly melt the mtl then pump it,,, most roofers only own directly fired pots
Yes it is applied hot, and you do need a different pot than what the felt roofers use.
Maybe the Pilgrims forgot to take one on the boat
stuart45 is offline   Reply With Quote
Old 12-06-2013, 07:29 AM   #17
Hello All :-) I've gotten so much information that I'm now confused??? Should I put something on the Slab to bring down the 25% moisture reading?? Or should I just put down carpet with a pad that does not have a moisture barrier on it? Then the carpet over it. This house had carpet on the Slab for 15 years, and when pulled up it had no mold??? Just a lot of white salt on the slab?? Is letting the carpet breath the only solution??? Tks, Bob
bobzollo is offline   Reply With Quote
Old 12-06-2013, 07:44 AM   #18
Rewards Points: 4,586
http://www.cimline.com/pages/magma-110.html - these are what we used for hgwy jnt/crk sealing,,, occasionally we'd get jobs from roofers or gc's in the city - mostly rooftop gardens & pool stuff on hi-rises,,, ga just bought 3 for some district maint sheds,,, google astm 1190 or astm 3405 for the mtl we used,,, merry Christmas !
cement slab grade fix? handyman_squire Concrete, Stone & Masonry 14 10-21-2012 08:13 AM
Concrete Slab on Grade - Moisture Issues, But How? BobSmitt Flooring 9 11-18-2011 03:56 PM
house concrete slab moisture Korey Flooring 4 07-18-2011 12:10 PM
Sealing/painting cement slab for humidity? mcu Flooring 2 04-24-2008 09:53 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
