Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-07-2012, 10:28 AM   #1
Cement hearth
Had to remove false floor in front of fireplace because prior owner did't replace properly, had some of the false floor burned. Cut away false floor, now down to concrete, its a basement family room. Made a mold for hearth, what can I do to ensure bondage of the new 4 inch hearth to the cement floor?
doreenz is offline   Reply With Quote
Old 03-07-2012, 10:30 AM   #2
Cement hearth
How thick do you plan on poring it?
What are you putting over the concrete?
Clean the floor, remove any sealer, use concrete bonding agent.
doreenz (03-07-2012)
Old 03-07-2012, 10:38 AM   #3
Cement hearth
pouring 4 inches of new concrete was thinking about some brick, what do you think?
Weight Support beneath brick hearth shub Building & Construction 2 01-10-2012 09:30 PM
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 3 05-15-2011 02:45 PM
general question on portland cement rtoni Building & Construction 2 07-11-2009 09:32 AM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
