-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   cement floor fix (http://www.diychatroom.com/f105/cement-floor-fix-155221/)
senior-chief 08-29-2012 02:46 PM
cement floor fix
Good afternoon-My question is that in my workshop a section of concrete has fallen apart--the area is-10" x 6"-What would be the best way to correct this problem--It in the cellar and in Upstate NY--Any help will be greatly appreciated---:)
joecaption 08-29-2012 02:48 PM
Post a picture. your there and can see it, were not.
Canarywood1 08-30-2012 01:23 PM
Clean out the broken material,then get a bag of sakrete mix enough to fill the hole,and your done.
LMHmedchem 09-02-2012 11:46 PM
Do you have an outright hole in the floor, or is the surface just broken up? A picture would help.
If the defect is deep enough, then any kind of concrete more or less will work because you can float some paste to the top to get a good finish. When you are trying to resurface areas where you just need to add 1/4" or so to the top, you need something smooth and I think it is better to make it up from portland cement and sand. I also find the concrete adhesive helps some.
LMHmedchem
user1007 09-03-2012 08:15 AM
If it is just the surface, and budget allows, epoxy can actually work better than concrete and will bond better with the material under it. I use materials from Abatron but there are others out there. The Abatron material is very strong and easy to tool.
If the section has failed all the way down you will need to chip it out and pour and surface a new section.
Before doing anything have you determined the cause of the failure? Do you have a foot and corner of a piece of heavy shop equipment sitting on too thin a slab? If you put a veneer repair down it will fail in short order if this is the case.
