Caulking Gun Tubes ( Empty ) - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-25-2012, 11:57 AM   #1
Rewards Points: 1,690
Caulking Gun Tubes ( empty )
I need to do a small tuck pointing job on some bricks and fill some voids with mortar that really isn't a pointing job and was thinking if empty caulking tubes were available the tip could be cut the size desired for each area and would be handier and quicker than wrestling a grout bag.
Anyone know if caulking gun tubes only are available? If not, you build it I'll buy it.
Old 09-25-2012, 12:10 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Wow talk about a Niche Market
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-25-2012, 04:33 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Use a Pastry Bag.
- Build Well -
Old 09-26-2012, 01:18 AM   #4
Rewards Points: 152
Just found these today...
http://www.amazon.com/CRL-Plastic-Se...ing+caulk+tube
TRUEPRO is offline   Reply With Quote
Old 09-26-2012, 03:28 AM   #5
Tool Geek
PaliBob's Avatar
Wow! The Niche Market is alive.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-26-2012, 08:48 PM   #6
Msradell's Avatar
Rewards Points: 276
Here is that even cheaper option: http://www.amazon.com/FILLABLE-CAULK...ef=pd_sim_hi_1 must be more demand for them that we thought!
Msradell is offline   Reply With Quote
Old 09-27-2012, 07:34 AM   #7
Concrete & Masonry
Rewards Points: 620
You're not going to get mortar to run through one of those tubes, it's doesn't flow well enough. There are bulk style "caulk guns" that will pump mortar through but they're over $100, and work OK at best IMO. For small tuckpointing, a trowel & filler, or a grout bag, are going to be much more efficient approaches.......
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
PaliBob (09-29-2012)
Bathroom floor/tub and caulking soulstar General DIY Discussions 5 11-10-2011 10:49 PM
Caulking a Bathtub, need advice RealMarkP Plumbing 5 03-12-2011 05:25 PM
caulking tile backsplash--he sprayed something on the caulking then used his finger Limit54 Tiling, ceramics, marble 6 12-06-2010 05:45 PM
Caulking Exterior Windows unixb0y Painting 1 06-04-2009 05:31 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
