Capping Vent In Brick Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-04-2012, 10:37 PM   #1
I am in the process of selling our house as we get ready to move overseas, and the home inspector just dinged us for a vent through the exterior brick wall into our (now enclosed) carport. I'm going to go ahead and cap it myself but was curious as to the "best" method to do so. Brick and mortar? Something else entirely?
Appreciate any and all suggestions...my focus is carpentry and woodworking. Masonry is a new one for me.
Mac
Adding pictures to illustrate.
amack is offline   Reply With Quote
Old 04-10-2012, 08:53 PM   #2
Rewards Points: 152
Remove vent. Replace with brick. They will not match but your problem will be solved. Masonry isnt exactly a DIY type project but i would charge about 150 to do this repair material included.
TRUEPRO is offline   Reply With Quote
Old 04-10-2012, 09:02 PM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
You do realize that the inspector for the buyer is in no position to tell you what needs to be fixed.
He makes recommendations to the buyer on what should be corrected.
If the buyer wants it fixed,work it into the sale price.Get an estimate to fix it and offer half to the buyer and let them fix it if they want it fixed.
Can't see that being a deal breaker for the buyer.
Of course if you want the challenge of fixing it you can do that too.
sublime2 is offline   Reply With Quote
Old 04-10-2012, 09:42 PM   #4
Yeah, painfully aware of all that. Our first response on this was a flat no. Went back and forth with buyer and for whatever reason it was important to him. I'm struggling with the necessity of paying a contractor for what appears to me to be something not too terribly difficult to fix. So, our final response was that I'd fix this myself. Plan right now is just to yank the vent out and brick up the opening (vent is non functional, not tied into the oven or anything). Thought I'd post here and get some ideas.
Old 04-10-2012, 09:53 PM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Couple of problems with that.
You fix it then the buyer backs out for another reason.
Or,you fix it but it's not to their liking.
That's why it's better to work that into the sale price and let them do the repair.
If your going to fix it,HD sells a small plastic bag with cement in it just add water. About 8 bucks for the bag. If you have a brick in your back yard or front yard or basement that matches those already there use it.
Good luck!
Old 04-10-2012, 10:18 PM   #6
Rewards Points: 152
The above described way to fix it is wrong. You have to do it the RIGHT way or risk critique from potential buyer. The right way to do it is use a 14 inch diamond saw and tooth the bricks so whole bricks can be installed, not half brick and pieces to fill the void leaving a straight joint up the side that will look terrible. Never ever use a premix BS sold at HD or Lowes, the result will not be pretty. I do agree with sublimes statement about leaving it up to the buyer to make the repair because once your tear out that vent your left with a project that you might not want to be involved in. Work it out with the buyers so you dont have to hear complaints if the repair doesnt turn out as planned.
Old 04-22-2012, 07:15 AM   #7
Gents, thanks much. Buyer actually opted for something even easier. Just wants it covered so is happy for me to pull the old vent cap off and cover with a regular old metal flat duct cap. Whatever. Thanks again!
Old 04-22-2012, 08:44 AM   #8
Rewards Points: 2,516
If I was the buyer and the repair was a deal breaker I would insist the repair be done by a licensed professional with receipts. But glad to see your snafu was remedied.
hammerlane is offline   Reply With Quote
Old 04-22-2012, 09:11 AM   #9
Ravenworks's Avatar
Just curious,what did the inspector say about the cover on you J-Box ?
Ravenworks is offline   Reply With Quote
Old 04-26-2012, 03:24 PM   #10
Inspector just said vent should be "capped". I proposed this fix as plan b (bricks were first). Buyer requested just a vent cap. No follow up inspection req'd/requested after the job completed.
Old 04-29-2012, 08:14 PM   #11
Msradell's Avatar
Rewards Points: 126
I was wondering the exact same thing, it certainly appears to be a potentially bigger problem than the vent.
Msradell is online now   Reply With Quote
Old 04-30-2012, 12:14 PM   #12
Doh! Misread this earlier. The inspector didn't write up a thing on the junction box. What's the issue?
Old 04-30-2012, 12:34 PM   #13
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
I'm guessing the issue is that box is outside and its not an outdoor/ weatherproof rated box.(it appears metal).
Old 04-30-2012, 01:01 PM   #14
Msradell's Avatar
Rewards Points: 126
Exactly! Being outside it definitely needs to be a weatherproof box. Just shows how inspectors only find what they want to find, which usually isn't a lot.
Old 04-30-2012, 02:47 PM   #15
But it isn't! The wall you're seeing is internal (garage).
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 04:07 PM
Attaching Willow Screen to brick wall tripled Landscaping & Lawn Care 5 08-12-2011 07:46 AM
Moisture concerns building against a brick wall (PICTURES) aluminum13 Building & Construction 8 05-17-2011 09:07 AM
Hanging a joist in an 1895 brick wall billydwilliams Building & Construction 4 03-28-2011 04:09 PM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 06:45 PM
