-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Capping vent in brick wall (http://www.diychatroom.com/f105/capping-vent-brick-wall-139270/)
amack 04-04-2012 09:37 PM
1 Attachment(s)
I am in the process of selling our house as we get ready to move overseas, and the home inspector just dinged us for a vent through the exterior brick wall into our (now enclosed) carport. I'm going to go ahead and cap it myself but was curious as to the "best" method to do so. Brick and mortar? Something else entirely?
Appreciate any and all suggestions...my focus is carpentry and woodworking. Masonry is a new one for me.
Mac
Adding pictures to illustrate.
Attachment 48553
TRUEPRO 04-10-2012 07:53 PM
Remove vent. Replace with brick. They will not match but your problem will be solved. Masonry isnt exactly a DIY type project but i would charge about 150 to do this repair material included.
sublime2 04-10-2012 08:02 PM
You do realize that the inspector for the buyer is in no position to tell you what needs to be fixed.
He makes recommendations to the buyer on what should be corrected.
If the buyer wants it fixed,work it into the sale price.Get an estimate to fix it and offer half to the buyer and let them fix it if they want it fixed.
Can't see that being a deal breaker for the buyer.
Of course if you want the challenge of fixing it you can do that too.
amack 04-10-2012 08:42 PM
Yeah, painfully aware of all that. Our first response on this was a flat no. Went back and forth with buyer and for whatever reason it was important to him. I'm struggling with the necessity of paying a contractor for what appears to me to be something not too terribly difficult to fix. So, our final response was that I'd fix this myself. Plan right now is just to yank the vent out and brick up the opening (vent is non functional, not tied into the oven or anything). Thought I'd post here and get some ideas.
sublime2 04-10-2012 08:53 PM
Couple of problems with that.
You fix it then the buyer backs out for another reason.
Or,you fix it but it's not to their liking.
That's why it's better to work that into the sale price and let them do the repair.
If your going to fix it,HD sells a small plastic bag with cement in it just add water. About 8 bucks for the bag. If you have a brick in your back yard or front yard or basement that matches those already there use it.
Good luck!
TRUEPRO 04-10-2012 09:18 PM
The above described way to fix it is wrong. You have to do it the RIGHT way or risk critique from potential buyer. The right way to do it is use a 14 inch diamond saw and tooth the bricks so whole bricks can be installed, not half brick and pieces to fill the void leaving a straight joint up the side that will look terrible. Never ever use a premix BS sold at HD or Lowes, the result will not be pretty. I do agree with sublimes statement about leaving it up to the buyer to make the repair because once your tear out that vent your left with a project that you might not want to be involved in. Work it out with the buyers so you dont have to hear complaints if the repair doesnt turn out as planned.
amack 04-22-2012 06:15 AM
Gents, thanks much. Buyer actually opted for something even easier. Just wants it covered so is happy for me to pull the old vent cap off and cover with a regular old metal flat duct cap. Whatever. Thanks again!
hammerlane 04-22-2012 07:44 AM
If I was the buyer and the repair was a deal breaker I would insist the repair be done by a licensed professional with receipts. But glad to see your snafu was remedied.
Ravenworks 04-22-2012 08:11 AM
Just curious,what did the inspector say about the cover on you J-Box ?
amack 04-26-2012 02:24 PM
Inspector just said vent should be "capped". I proposed this fix as plan b (bricks were first). Buyer requested just a vent cap. No follow up inspection req'd/requested after the job completed.
Msradell 04-29-2012 07:14 PM
I was wondering the exact same thing, it certainly appears to be a potentially bigger problem than the vent.
amack 04-30-2012 11:14 AM
Doh! Misread this earlier. The inspector didn't write up a thing on the junction box. What's the issue?
sublime2 04-30-2012 11:34 AM
I'm guessing the issue is that box is outside and its not an outdoor/ weatherproof rated box.(it appears metal).
Msradell 04-30-2012 12:01 PM
Exactly! Being outside it definitely needs to be a weatherproof box. Just shows how inspectors only find what they want to find, which usually isn't a lot.
amack 04-30-2012 01:47 PM
But it isn't! The wall you're seeing is internal (garage).
