Cap On Concrete Porch - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-20-2012, 11:50 AM   #1
cap on concrete porch
The front porch on my house is slanted towards the house with about an 1 1/2 inch drop at the house side. I really don't want to go to the expense of tear out and replace. Can the concrete be capped with more concrete? Keep in mind by the house it would be 1 1/2 thick but at the step it would be more like 1/2 inch. What kind of mix would I need to use or maybe an epoxy? Any suggestions will be appreciated. Thanks to all in advance.
sundancer1029 is offline   Reply With Quote
Old 09-20-2012, 06:42 PM   #2
Rewards Points: 14,020
Old concrete does not like to stick to new.
A thin layer is just going to crack.
Can you post a picture.
Did the part near the house sink, or was it just pored wrong?
Old 09-20-2012, 07:11 PM   #3
Rewards Points: 1,694
Check with a local concrete ready mix company and see if they can supply you with a industrial epoxy self leveling grout or they may be familiar with someone who can. The manufacturer's instruction sheet would need to be strictly adhered to for application. Being self leveling it would be difficult to slope for drainage but at least the porch wouldn't slope to the structure.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
sundancer1029 (09-21-2012)
Old 09-21-2012, 08:15 AM   #4
World's Tallest Midget
Mort's Avatar
Rewards Points: 694
Call a slab jacking company. Rather than putting something over the top, raising it up would be the correct fix if you don't want to tear it out.
I hate signatures.
Mort is online now   Reply With Quote
The Following User Says Thank You to Mort For This Useful Post:
Old 09-21-2012, 11:40 AM   #5
It's an older house so I'm guessing it has just settled. I'll take a picture and post. Thanks.
raised concrete slab porch tootie Concrete, Stone & Masonry 18 05-23-2012 10:19 AM
concrete porch issues.... need help JulesB Concrete, Stone & Masonry 15 05-17-2012 07:30 PM
mounting 4x4 wood post to concrete porch pshinaults Building & Construction 1 05-27-2010 02:53 PM
adding a deck to existing concrete porch idiotbox37 Carpentry 6 12-02-2009 07:48 PM
replace porch post on concrete slab maa40 Building & Construction 2 03-23-2008 10:50 AM
