Can't Match Brick - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-23-2013, 10:52 AM   #1
Can't match brick
I would like to find a manufacturer that would do a run of the brick that I need. Is there a place in Arkansas that will do this?
mslakesider is offline   Reply With Quote
Old 09-23-2013, 11:37 AM   #2
Rewards Points: 13,694
I'd spend more time trying to find matching brick before I'd go that route.
Old 09-23-2013, 12:33 PM   #3
concretemasonry's Avatar
Rewards Points: 2,608
It will be tough to find and exact match. - Take a sample to a good brick suppliers and they usually have access to sample boards to find something very close. If you are lucky they may find and exact match that could be available.
Even getting a special run (if possible) would be very, very costly and still may not be exact because the clay deposits change slowly over time as they are mined in different areas.
A run of brick represents many days of production because most plants extrude and fire brick continuously on a 24 hour schedule.
Dick
concretemasonry is offline   Reply With Quote
wrought iron security door frame diy888 Windows and Doors 6 02-22-2016 07:08 AM
Patching "holes" in exposed brick chimney CaptChaos Building & Construction 5 01-17-2012 03:09 PM
Brick veneer is 4 rows below grade- redo or leave? cbrc5eric Building & Construction 11 12-27-2011 08:09 PM
Exterior Brick Wall with No Sheathing? beesan Building & Construction 1 12-08-2009 05:57 AM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 03:04 PM
