Can You Put Stone Over Brick? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-20-2017, 09:02 PM   #1
Rewards Points: 6
Can you put veneered stone over existing painted brick like on this fireplace? If so how?
srj11 is offline   Reply With Quote
Old 04-20-2017, 09:10 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
Re: Can You Put Stone Over Brick?
Yes you 'can'.....
However, in your case, the paint on the brick is going to be your weak point
I'm willing to bet that brick has no structural value....it's just 'stuck' there, just like ledger stone would be. You might be better off pulling off the brick.
Another option....anchor cement board to your existing brick..the attach your stone to that...
But that is going to make for a pretty big bump out...
Old 04-20-2017, 10:35 PM   #3
Rewards Points: 6
Bummer. thx. How should I get the brick off without damaging the block under it?
Old 04-21-2017, 01:17 AM   #4
JOATMON
ddawg16's Avatar
Location? And when was the house built?
I'm assuming the fireplace is original with the house?
Old 04-21-2017, 03:21 AM   #5
Rewards Points: 4
Yes, you can install stone veneer over brick. But it is not as easy as trowelling mortar onto the brick and applying veneer. Like other surfaces, the brick must be prepared correctly.
You need mesh. While veneer is a fraction of the weight of full stone, it is not light. The mesh forms a framework that the bonding material will surround and be inseparable from it (absent smashing with a hammer). The mesh is firmly attached to the underlying structure with fasteners (type depending on the nature of the siding).
John_7878 is offline   Reply With Quote
Can You Put Stone Over Brick? srj11 Concrete, Stone & Masonry 2 04-21-2017 10:35 AM
Stone Tile Over Brick Fireplace - Did I Make a Mistake? Zach_C Concrete, Stone & Masonry 4 04-13-2013 11:38 AM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
J-Weep / Flashing for exterior cultured stone veneer wall. Spud Building & Construction 18 08-31-2009 09:44 PM
Adding stone to existing brick chimney TVC15 Building & Construction 5 08-13-2008 05:19 PM
