Can You Mortar The Joints Right After Setting The Stone? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-26-2013, 08:15 AM   #1
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
Or do you have to wait a day or so? I've got a small weather window coming up and I need to get this done.
JulieMor is offline   Reply With Quote
Old 10-27-2013, 06:08 AM   #2
Rewards Points: 4,752
i would wait a day @ least so i get separation between mortars
The Following User Says Thank You to stadry For This Useful Post:
JulieMor (10-27-2013)
Old 10-27-2013, 08:57 AM   #3
JulieMor's Avatar
Rewards Points: 518
Thanks! I've read everything from the stone & mortar manufacturers and nowhere did I read about allowing time between setting the stone and grouting but in the back of my mind something seemed wrong with doing one right after the other. We'll wait.
Thanks again!
Old 10-29-2013, 07:57 AM   #4
Concrete & Masonry
Rewards Points: 620
We generally grout another day, as the joints will set faster this way. On certain work, like narrow chimneys that require scaffold though, it's not uncommon for us to apply stone and grout the same day. This way we can work our way down the scaffold and not have to go back up again.......
jomama45 is offline   Reply With Quote
Tile Floor / Electrical Radiant Heat / Mortar Not Setting aaldrich55443 Flooring 5 01-08-2013 07:35 AM
Loose mortar in stone veneer bettyw99 Concrete, Stone & Masonry 6 09-01-2012 05:53 PM
setting paver stone amakarevic Landscaping & Lawn Care 2 08-14-2012 04:09 PM
Plaster/Render patching over interior stone wall eric_o83 General DIY Discussions 0 10-21-2011 06:41 PM
setting tub in mortar? ponch37300 Building & Construction 5 03-15-2008 10:06 PM
