Can You Clean Cement Off The Face Of A Block Wall? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-06-2012, 10:11 AM   #1
kmc
Can you clean cement off the face of a block wall?
I did some block work yesterday with regular mortar mix and regular tan building blocks. After smoothing in the gaps with the mortar mix, I left some grey residue on the blocks that I's like to clean up. So I'm wondering if it is possible to wipe the face of the blocks clean with something to get the cement off. Any ideas?
kmc is offline   Reply With Quote
Old 03-06-2012, 10:33 AM   #2
removed by poster
Hardway is offline   Reply With Quote
Old 03-06-2012, 11:28 AM   #3
Concrete & Masonry
Rewards Points: 470
If it's less than a day old, I would just get a scrub brush, bucket of water & some laundry detergent and use a little elbow grease.
If that doesn't work, try a little white vinegar & water.
Muratic is the last thing I would use on day old block, especially if the block are custom colored..........
jomama45 is offline   Reply With Quote
Old 03-06-2012, 11:29 AM   #4
Ravenworks's Avatar
Be very careful with Muriatic acid,you must neutralise it when you're done.
"Sure Klean 600" is the industry standard, here is a link to there products http://www.prosoco.com/
Ravenworks is offline   Reply With Quote
Old 03-06-2012, 11:54 AM   #5
kmc
Thanks, I will check it out when I get home and maybe take a scrub pad to it. It's actually the neighbors wall that I repaired for free where it ties into my new wall. I don't really care about the look but I don't like to leave shoddy work either. If it looks like crap a month from now then I will look into the Sure Klean 600 or muriatic acid.
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 10:32 PM
Cement Block Wall Footing 99altrade Building & Construction 41 08-10-2011 01:39 PM
Mortar bed removal from block wall Douger_F Building & Construction 8 04-15-2009 08:47 AM
Half-height Cinder Block wall Electrical theatretch85 Electrical 11 04-09-2009 12:49 AM
Cracks In Block Wall Foundation vf100 Building & Construction 7 08-20-2008 10:48 PM
