Can I Use Concrete To Repair A Small Brick Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-10-2014, 08:28 PM   #1
Indepspirit's Avatar
Can I use concrete to repair a small brick wall
We have a small brick wall in front of our mobile home that corners around it for 3 feet. At the corners the wall is separating slightly. Was going to buy some mortar and a bag to fill in the cracks. However after our patio project have a half of bag of quickrete left over. Can I mix it up to fill in the gaps? The wall is purely cosmetic and in no way structural and once the gaps are filled in we will be painting the bricks.
Sent from my SAMSUNG-SGH-I527 using Tapatalk
Plants are like people no two alike. What I do for my plants may not work for your plants.
Dirt Ain't Cheap (my landscaping blog)
Indepspirit is offline   Reply With Quote
Old 05-10-2014, 08:43 PM   #2
Rewards Points: 1,686
I'd think one would deed to screen the rock out to have the slightest chance of being successful.
Old 05-10-2014, 08:50 PM   #3
Was thinking the same type of thing and think the chance would be slim for it to hold up. Just trying to fill holes but concrete is not made to go vertical. Was trying to save money and use up what I had.
Old 05-11-2014, 08:10 AM   #4
Rewards Points: 14,020
Can you post a picture?
Sure sounds like a poor footing that's failing.
Use mortar not concrete to fill gaps.
Mixing it up and applying with a mortar bag will make less mess. Looks like a pastry bag.
Old 05-11-2014, 10:11 AM   #5
Rob
Robpo's Avatar
Rewards Points: 826
If you are going to paint it and the gaps are not big, I would use caulk. If it is not structurally sound nothing will stop it from cracking. It will be difficult to screen concrete mix.
Robpo is offline   Reply With Quote
Old 05-11-2014, 11:24 AM   #6
The wall is there for looks only so we're not to concerned if it's structurally sound. Just wanted to fill in the gaps to make it look better. I think a tree root is causing the separation. Off to buy some mortar and a bag.
Can I use concrete to repair a small brick wall-uploadfromtaptalk1399825162850.jpg
Old 05-11-2014, 09:28 PM   #7
Msradell's Avatar
Rewards Points: 276
As Rob suggested caulking would probably be a better solution to fill those gaps. It would certainly be much easier to apply in would stick better to those already painted surfaces.
Msradell is offline   Reply With Quote
Old 05-11-2014, 10:13 PM   #8
Jmayspaint's Avatar
Rewards Points: 534
Yes, some backer rod and calk would flex some with future movement.
This stuff looks like mortar and is paintable when dry.
http://www.sashco.com/products/mor-flexx/
Jmayspaint is offline   Reply With Quote
Old 05-12-2014, 12:26 AM   #9
Rewards Points: 744
I'd get some metal on the backside of that corner, to keep it from moving further.
Seattle2k is offline   Reply With Quote
Mounting 60" LCD to thin concrete wall flatblackstrat Concrete, Stone & Masonry 7 02-18-2013 07:21 PM
Hydronic baseboard mounted to concrete wall Maine1 Remodeling 20 12-26-2012 06:08 AM
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 03:07 PM
my concrete retaining wall has a major crack where the wall has now shifted DanDaMan Building & Construction 1 04-02-2011 11:34 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
