Can I Cover My Cement Steps? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-07-2014, 10:32 PM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Can I cover my cement steps?
Wow, I haven't been here for a while........
I have a crack in my front steps. Is there any type of cut stone that I can put on the steps and the risers? Something that I don't have to cut.
Thanks you wonderful folks here.
http://diyitnow.blogspot.com
yummy mummy is offline   Reply With Quote
Old 07-07-2014, 11:48 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 2,120
Unless your steps are exactly the right width to match the size of the stones or tiles.....No.
Before you try to cover the crack......just how big is that crack? And why do you have a crack? If it's getting bigger....you're going to have a bigger problem if you cover it.
For the record....it's not a big deal cutting stone. Yes I have a tile saw...but I have also used a skillsaw with stone cutting blade. It's not hard to cut the stone...messy....but not hard.
ddawg16 is online now   Reply With Quote
Old 07-09-2014, 08:50 AM   #3
Thanks for your reply dd.
The crack is not on the step its at the bottom of the riser. I think the frost moved the whole things and cracked.
I really don't want to cut stone. I just wanted to put something over the whole thing so that it would look nice and cover that crack. Something easy.
Is there anything else that I can do?
Old 07-09-2014, 09:05 AM   #4
kwikfishron's Avatar
Rewards Points: 1,002
There are a lot things you could use to cover concrete steps. The problem is you'll end changing the rise of the first and last step of whatever the thickness of the material you choose. The first step will end up taller with the last step shorter. This will create a trip hazarded.
In most places code only allows for a maximum of a 3/8" variance in the rise of the steps. So to cover the steps in outdoor carpet for example likely would not create any issues, anything thicker probably would.
kwikfishron is online now   Reply With Quote
covering cement basement steps awisniewski Concrete, Stone & Masonry 2 06-22-2012 11:13 PM
Cement slab touches buildings cbuisman Building & Construction 2 06-09-2009 10:24 PM
Removing cement stairs for future deck smithfly114 Building & Construction 6 02-21-2009 06:18 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 12:53 PM
