Can I Cover Asphalt With Concrete In A Garage? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-14-2012, 08:18 PM   #1
Can I cover asphalt with concrete in a garage?
About forty years ago the previous owner of my house had the floor of the garage portion of the barn covered with asphalt. It's still in good shape, but I'd like a smoother surface, like concrete. Or maybe tile.
Would a thin layer of concrete just break up?
Is there an easy way to lay tile on asphalt?
fitzaer is offline   Reply With Quote
Old 09-14-2012, 10:26 PM   #2
Rewards Points: 162
I would pull the asphalt up - a thin layer of concrete on top of asphalt would be prone to cracking and may break up easy. You want a good consistent thickness of concrete on top of a properly compacted granular base.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 09-15-2012, 01:05 AM   #3
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
Asphalt is surprisingly easy to remove. There's almost no strength to it: 125 pounds per square foot, as opposed to 4000 pounds per square inch for concrete. Just dig it up.
Mort is online now   Reply With Quote
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
Replacing a garage door with Concrete block wall Domenick Building & Construction 5 06-12-2012 11:19 AM
Can you Asphalt over a Concrete Driveway? psubaron Concrete, Stone & Masonry 8 03-06-2012 07:22 PM
How to repair concrete in front of garage picflight Building & Construction 2 10-28-2011 05:27 PM
Concrete Driveway - Asphalt Over Top? mark2741 Building & Construction 1 03-22-2011 04:42 PM
