Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-06-2012, 04:07 PM   #1
can a fireplace flue be installed AFTER?
People,
My new house- built in the 40'2s, has no chimney flu (the cast iron assembly thingy that has a lever to shut the chimney during non use).
Im guessing you cant simply "mortar in" a flu afterward, right? Is this a huge chore? Spiders (widows) like to come down there, cold draft in winter, etc. Advice appreciated.
NoQ
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 06-06-2012, 05:28 PM   #2
joed's Avatar
I think what you mean is a damper. You can certainly a damper as well as a liner now. The liner will be a metal flexible one. You can also install the top locking cap that seals the chimney to the top of the existing chimney when not in use.
Do not PM with questions that can be asked in a forum. I will not respond.
The Following User Says Thank You to joed For This Useful Post:
noquacks (06-06-2012)
Old 06-06-2012, 07:04 PM   #3
Geez, my mix up, joe. Yes, a damper! So, wheres a good lace to buy one and how does one measure? (cap also good idea.)
Old 06-06-2012, 07:16 PM   #4
I have gas!
Clutchcargo's Avatar
Get a cap damper combo. Like one of these
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
The Following User Says Thank You to Clutchcargo For This Useful Post:
Old 06-06-2012, 07:20 PM   #5
How long ago was this chimmney checked and clean by a sweep?
May want to concider have them check this and install the flue at the same time.
Old 06-06-2012, 07:27 PM   #6
excellent link clutch! One of those caps will be a dual purpose item! Easy tio install, it appears too.
Old 06-06-2012, 07:29 PM   #7
Who knows- house was neglected. I'll get a chimney sweep to check it out to be safe. I did peek under there with light, and hardly any creosote residue at all. Anywa, man, Im on the right track! Thnaks, people.
fireplace ssheehan General Discussion 3 04-25-2012 03:55 PM
gas hot water tank flue kenco77 Plumbing 2 04-11-2012 10:59 AM
Fireplace Phreek Remodeling 1 11-10-2011 07:26 AM
flooring around a fireplace. liquidvw Flooring 3 07-25-2010 03:23 PM
