Can Anyone Explain This Basement Slab Issue? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-07-2012, 04:41 PM   #1
Can anyone explain this basement slab issue?
Hi there.
I found some rotted out studs in one corner of my basement while laying a new floor.
After tearing out the wall ( and then another wall ), I found that there is an area between where it seems the slab ends and cinder blocks begin where there is a bunch of rocks filled into broken away concrete.
It almost looks like the wall was moved in ( which I don't think is what really happened ). But it definitely looks like this was done purposely as this only starts at one wall and goes around the corner up until there is a column of cinder blocks which are stacked next to the regular wall. I also found pieces of broken concrete which match the broken floor concrete in a part of the wall that doesn't have this problem.
Has anyone ever seen something like this?
Sorry for rambling on, but I'd really like to get to the bottom of this. Photos on the way.
Thanks.
jeffdoubleyou is offline   Reply With Quote
Old 10-07-2012, 04:51 PM   #2
Pics
https://docs.google.com/open?id=0B0O...nIwV3l4THh2QkE
https://docs.google.com/open?id=0B0O...Ec3UzMwdUNoS3M
https://docs.google.com/open?id=0B0O...kQtdXdTS1RtQ2s
https://docs.google.com/open?id=0B0O...zF6TzB3azFETXc
Lower Slab Under Girders in Basement benjamincall Concrete, Stone & Masonry 8 04-25-2012 01:29 AM
how to reduce mositure issue on basement? diy001 Building & Construction 0 10-28-2011 12:44 PM
Need help figuring out walk-out basement water intrusion issue toomanypets General DIY Discussions 18 08-29-2011 08:34 PM
basement water issue zoolou Building & Construction 4 12-05-2010 05:05 PM
Basement framing Issue, need help jthawkins Building & Construction 14 03-09-2009 03:15 PM
